Qeunching Oil
What type of oil should you use to quench. I heard you can use regular motor oil, if so what kind.
Thanks
John
Depending on the steel type quenched a lot of different oils will work. Both petroleum based and organic like vegetable oils. Some steels need a faster than oil quench, so that is where the steel type comes into play. Some folks frown on the motor oil quench and I understand it but the point is that it *will* work alright. Just stinks and can flare up into flame and gives off some noxious fumes... I've used a mixture of 30 weight motor oil, a couple gallons of diesel fuel, and a cup or 2 of dish soap in there and it works pretty well. Not the best smelling, but it will do the job on things that won't fit into my salt tube...
If you want some very good quality oil made to do the job, do some research into the commercial quenchants. There are a variety out there and some are pretty expensive, but they also are designed specifically for quenching, which is not something motor oil, transmission fluid, hydraulic fluid, etc. is made for...
Re: Qeunching Oil
Thanks
John
Hey John,
Like Scott said, you can use motor oil, but I wouldn't recommend it at all. The stuff smells bad, and will likely make a large mess of your shop, plus if you are tempering in your home oven, it will make the entire kitchen smell like a garage.
Regular old vegetable oil works rather well, and it fairly cheap, especially is you are just starting out and are on a budget. Peanut oil also works well, if you can get ahold of a large quantity. If you take a long time between projects, you might have to change out the oil, as organics can and will occasionally go rancid.
On the more expensive side of things, there are a few companies out there that specialize in heat-treating and quenching oils specifically for doing bladework. Another step above these is to set up a molten salt rig, but that is a much more expensive route to go.
What type of steel you are using will dictate the type of heat-treating routine you will want incorporate.
Hope this helps.
Qeunching Oil
Where can I get alot of vegetable oil.
Thanls
John
Re: Qeunching Oil
You can find it at the grocery store all day long... ask someone where the biggest jug is. Another option might be a warehouse store like Sam's Club. Also, a restaraunt supply store might be able to help you out - check your local yellow pages...
I use peanut oil. It works pretty good and smells like doughnuts.........
Mmmmmmmmmm....... Doughnuts.
