Markus Fischer
Posted: Fri 04 Jun, 2021 2:53 pm Post subject: Thickness of Helmets |
I recently watched the YouTube video from Tods Workshop, in which he shot historically accurate longbow arrows from his "lockdown-longbow" which shoots these arrows at the same speed as a british 160lbs yew longbow.
https://youtu.be/hc6dhMV_L54
In this specific video he shot the arrows at his Go-Pro protection device, which is a cheap/medium grade reenactment helmet with a polycarbonate visor.
One of the arrows passed cleanly through the front of the helmet and still had enough energie left to bounce of a steel tube on the helmets inside, as well as almost piercing a hole into the helmets backside.
At first Tod didnt comment much on this, because he thought the reason for that must be the rubbishy quality of the helmet.
But then he decided to measure the thickness at the spot in which the arrow penetrated, and it actually turned out to be 1,8mm thick.
https://youtu.be/v3QqdEX_ka8
And there comes my question:
How thick was the average medival european helmet?
There sure has been some enormous variation, so lets narrow our question down to a late 15th century sallet (i guess thats about what Tod shoots at in the video).
Probably there has also been some big variation within sallets, but if some people who are knowledgeable on this topic where to give some examples, we could come up with an approximation of the avarage sallet-thickness, in order to say how close this unintentional experiment would be.
I for myself dont know a whole lot about helmets, but I recently saw a reproduction of a sallet by Arma Bohemia at the price of 400€ or 490USD (I would consider this mid-range for a helmet) with the thickness being 1,5mm, so even less than the helmet in the video.
Of course one must also consider that Tods measuring device might be off a fair bit.
What do you think about this?
Edward Lee
Posted: Fri 04 Jun, 2021 4:13 pm Post subject: |
Suppousedly helmets thickness are like breastplates, thick on the top/center and it thins out to the sides. For example if the top helmet is 3mm thick and the side might thins out to around 1mm more or less, as it applies to breastplates.
http://myArmoury.com/talk/viewtopic.php?t=947...p;start=20
http://myArmoury.com/talk/viewtopic.31601.html
Regarding the 400 euro helmet, it's probably not heat treated. Regarding armor strength there is a big difference between heat treated armor and armor that are not. It is so in modern terms and I would think it applies to the past as well.
Sean Manning
Posted: Sat 05 Jun, 2021 8:39 am Post subject: Re: Thickness of Helmets |
Markus Fischer wrote: | How thick was the average medival european helmet?
People who were serious about armour in 14th-17th century Europe seem to have thought about three grades meant to defeat different threats. There was the basic kind which would usually stop a sword, there was the intermediate kind which would stop weaker missile weapons like longbows or pistols, and there was the strongest and heaviest kind which would stop the strongest one-man weapon of the day such as windlass crossbows or arquebuses. Combining all three grades of salet into one average would not be very helpful.
www.bookandsword.com
Mike Ruhala
Posted: Tue 08 Jun, 2021 7:21 pm Post subject: |
A historical sallet could be several times thicker in that area than the one Todd shot and he shot it with the equivalent of a 160lbs bow which is pretty darn powerful. A faster impact on a smaller surface area(such as the arrow) also has better puncturing characteristics than a slower impact over a wider area(such as a sword strike.) A lot of historical armor doesn't appear to have been made from thin sheet metal of uniform thickness like we use now, it looks like they were starting with thicker plates and drawing them out to get thick center sections that taper towards the edges. The thicker sections tend to be on the front and/or tops of helmets and some were massively thick in these areas, like a quarter inch!
Augusto Boer Bront
Location: Cividale del Friuli (UD) Italy Joined: 12 Nov 2009
Markus Fischer
Posted: Wed 30 Jun, 2021 2:25 am Post subject: |
Well, considering the big variation seen in these pieces on Pinterest, the test by Tod could be quite accurate.
In fact most of these helmets reached from 1,5mm to 2mm at the front, which means that Tods Helmet was pretty much in between with its 1,8mm.
So one could say that a number of historical helmets wouldnt protect you against warbow arrows.
At the same time I noticed, that the breastplates often were below 2,5mm in thickness (at least these particular examples) which is the thickness of the Agincourt Breastplate tested in the famous Arrows vs. Armour video.
This means that this test probably cannot be seen as an ultimate answer...the results may have been very different if they choose an other breastplate (even if its from the same time).
Very interesting...it seems like one can never be 100% sure about something beating something else, simply because the variation was too big.
Matthew P. Adams
Posted: Wed 30 Jun, 2021 12:33 pm Post subject: |
Then factor in the type of head used on the bolt. Was it a bodkin, a broadhead, how sharp, was it heat treated, and if so how well, can all factor in. Then movement, heads move both incedentally and also on impact. What happens if I'm turning my head, or I get jostled sideways? What's under my helmet? Am I wearing a padded arming cap? I know at one point men wore a secrete, a steel skull cap offering protection under a hat, were they ever worn together with a helm? I have no idea, but if so it would certainly add protection.
It's fun to run tests, and I certainly like watching them on YouTube, ESPECIALLY the Todd's Stuff channel, but it's really hard to draw any overarching conclusions from them. I know I'd take the sturdiest armor I could afford, and that any helmet is waaaay better than no helmet.
I ride a motorcycle and even though I'm an ATGAT rider (all the gear all the time) comfort can often be more important than protective qualities. The gear that fits is the gear that gets used. The point is that you could make an absolutely arrow proof helmet, but if it's hurting my spine I won't be able to wear it for a very long time. If I have an arrow proof helmet hanging from my saddle, or back in a wagon, it does me less good than a lighter weight, less protective helmet that I can wear on my head through 4 hours of heated battle.
Raman A
Posted: Tue 06 Jul, 2021 2:33 am Post subject: |
Check Matthias Goll's PhD thesis for measurements: http://myArmoury.com/talk/viewtopic.31261.html
Looking at Goll's data on sallets (what he calls type VII helmets) it looks like the average thickness actually is right at 1.8 mm. However, like Sean and pretty much everyone else already said, just looking at averages can be dangerous and we can't really draw any definite conclusions. First, my understanding is that Goll's measurements for sallets and armets are of the skull only and do not factor in overlap with the visor or brow-reinforcing plates, which could significantly increase the effective thickness at the overlapping areas. Second, thickness varies quite a bit between examples as well as at different spots on the same example. Some of the helmets had maximum thicknesses over 4 mm (although curiously those areas appear on the nape of the helmets and might just be a byproduct of their construction rather than an intended feature), while some helmets have areas less than 1 mm thick. At least one helmet has a spot only half a millimeter thick on the top-right of the skull. Many of the helmets have average thicknesses across their surface significantly higher than 1.8 mm, in the 2-3 mm range, while others are much lower.
There's also metallurgy to take into account. In Alan William's The Knight and the Blast Furnace he estimates that there's a quadratic correlation between plate thickness and energy necessary for a given projectile to penetrate, so even small differences in thickness can make a big difference in protection, but in the same book he also shows how much the metal quality in terms of hardness and micro-structure makes a difference. A thinner armor can potentially be as or more protective than a thicker one. In the Graz test a pistol penetrated 3 mm of modern mild steel but was stopped by a 3 mm section from a 1570 horse armor. "The fact that modern mild steel failed to absorb all the bullet's kinetic energy, while the 16th-century breastplate did, can probably be attributed to the early armourer's skill at cold-working the breastplate and hardening its surface." https://journals.lib.unb.ca/index.php/MCR/article/view/17669/22312
James Arlen Gillaspie
Posted: Tue 13 Jul, 2021 7:47 am Post subject: |
I may have missed someone else mentioning it, but another huge factor is RANGE. Missile weapons could usually be expected to operate in a certain range in the battle space, and Tod tends to be a bit close, because he doesn't want to miss. Also, charcoal iron and steel's laminated structure can be more difficult to penetrate due to its tendency to inhibit crack exploitation. The projectile produces a crack and widens it out to pass through, but a laminated structure means it cracks through the first layer and then has to start all over again with a lot less energy.
jamesarlen.com
Leo Todeschini
Posted: Tue 13 Jul, 2021 12:12 pm Post subject: |
James Gillespie wrote Quote: | I may have missed someone else mentioning it, but another huge factor is RANGE |
Yes I do tends to shoot close to minimise missing, and there is of course a velocity drop over distance, but I shot this at 25m and lets say a more viable range is 50 or 75m, the the velocity drop is enough to count, definitely. But not massive. I made a film about that a while back, but now cant remember without watching back, but the most loss over 100m was around 15% velocity I think so lets estimate now at around 10% loss over 60m which again as an estimate is a 20% energy drop or 15% momentum drop (sorry too lazy to do the maths late at night). That is significant, for sure, but 1.8mm may not get penetrated, although I think it was very conclusively through , but it would still definitely penetrate 1.5.
Can we conclude much from this? Not in the sense that we could put exact numbers to a result, but we can conclude that period thickness helms could be vulnerable to arrows from a reasonable distance.
Yes charcoal iron will behave differently and I hope to be coming to that soon, but mild is not known for crack propagation....
www.todsworkshop.com
www.todcutler.com
Posted: Tue 13 Jul, 2021 2:15 pm Post subject: |
Work-hardening is often an overlooked factor. A skilled smith is better at cold-working the metal so it doesn't need to be annealed as much, which leaves the final product (even low-carbon steel) significantly harder. This was demonstrated at the Graz test mentioned above where the modern plate was compromised by the pistol but the 16th century one (of similar thickness and carbon content) was not.
Graham Shearlaw
Posted: Tue 13 Jul, 2021 8:48 pm Post subject: |
Leo Todeschini wrote: | James Gillespie wrote Quote: | I may have missed someone else mentioning it, but another huge factor is RANGE |
Yes I do tends to shoot close to minimise missing, and there is of course a velocity drop over distance, but I shot this at 25m and lets say a more viable range is 50 or 75m, the the velocity drop is enough to count, definitely. But not massive. |
Its really with the huge speeds of musket shot where there's a large energy drop off due to aerodynamic drag.
See this table from The Graz Tests 1988-1989.
And as faster you go the more energy you need to over come air resistance, but that works both ways too an arrows are going a tenth as fast to start with.
And here is a PHD on all the maths about muskets and balls,
EXPERIMENTAL FIRING, AND ANALYSIS OF IMPACTED 17TH–18TH CENTURY LEAD
BULLETS by Parkman, Colin J.
http://eprints.hud.ac.uk/id/eprint/34911/1/Parkman%20THESIS.pdf
