Far Sale: LK CHen Heavenly Horse Dao and Sabersmith Gladius
Heavenly Horse Dao: $250 USD+ Shipping
Same Dao tested by Skallagrim. Very nice pattern welded blade. The adhesive holding the brass bolster on came loose during testing, but was re-glued using adhesive provided by lk chen. No issues since. Otherwise Sword is in excellent condition. Comes with Scabbard and silk bag.
Blade
Blade only weight: 580 g (1 lb. 4oz)
Sword only weight: approx. 600 g (1 lb. 5 oz)
Blade Length: 94 cm (37")
Handle Length: 13 cm (5.1")
Ring Length: 3.8 cm (1.5")
Total Length: 110.8 cm (43.6")
Gradual tapering
Width at hand guard: 25 mm, Width at tip: 20 mm
Thickness: 7 mm - 3 mm at the tip
Point of Balance: 25 cm (10") beyond hand guard
Blade cross section profile: triangular with slight ground
Blade length wide profile: subtle inner curve at the middle of the blade and subtle upward tip.
Folded pattern steel: 1065 carbon steel + T8 tungsten-cobalt-vanadium high-speed tool steel.
Superior heat treatment:
Hardness 54-55 HRC.
Sabersmith Gladius: 350 USD + Shipping
This Sword is a Tank, Very robust sharp edge, and good for backyard cutting. Satin Polish Blade with blackened Hilt components. Sword minimally used and in excellent condition. Comes with Scabbard and Frog.
Blade Length: 22.75 in
Overall Length: 30.25 in
Blade Width: 2 in
Weight:2.6 lb
Steel Type: 1075 High Carbon
Rockwell: 56 58c
Pictures in google Doc
https://docs.google.com/document/d/1ROrTxV9VFOKIfa_NV8aUbw2jPA7yTz86eWWiNgybdOQ/edit
Bump
Price Update
Price Update:
LKChen HH Dao-$225+shipping
Sabersmith Gladius: USD 325+shipping
Price Update
Lk Chen HH Dao: $200+ shipping
Sabersmith Gladius: $300+ shipping
Bump
Bump
Still available
Still available
Still available
Still available now
