This time I decided to make the smallest historically common type (about 5" blade with 4" handle, found a number of these in Bashford Dean and other sources). This is the kind of stiletto that was described as Oakeshott as "tiny weapons with blades like big needles, only some 5 to 6 inches long".
Most of these had solid steel turned handles, but I decided to go with less common wire wrapped handle (cheated a little on core material, used micarta for strength in such a small diameter). Wrap is twisted brass wire, guard and pommel filed out of 1018 steel and blackened.
Blade is 5" long and square in cross section, 3/16" at the base, with a decorative ball section filed near the guard. I made it out of 1084, quenched in oil using my improved homemade can forge, and tempered to what should be around low 50s hardness, softer than normal knife blade to make it less brittle.It is really needle pointed! Was quite a challenge for me to grind and heat treat such a delicate blade, but it came out perfectly even and straight!
Working on scabbard core now and trying to figure out how the scabbard should be constructed.
Any comments or critique are welcome!
