Hello!
I am selling this example of LK Chen's Infantry Dao.
This Sword is the one that Skallagrim reviewed, who then sold it to me. As stated in his video, some of the brass fittings did come loose, but I repaired them with glue provided by LK Chen, and have had no issues since. The blade is Sharp. With no bends, no chips, or rolls in the edge. Just some light surface scratches. Comes with Scabbard, and silk bag that the sword originally came with. The glue that LK Chen sent along to fix the fittings can be sent along as well if you want them.
Stats From LK Chen's Website
Blade only weight: 460 g (1 lb. 0.22 oz)
Sword only weight: approx. 480 g (1 lb. 0.9 oz)
Blade Length: 61 cm (24")
Handle Length: 11.5 cm (4.5")
Ring Length: 3.8 cm (1.5")
Total Length: 76 cm (30")
Gradual tapering
Width at hand guard: 25 mm, Width at tip: 20 mm
Thickness: 7.2 mm - 4 mm at the tip
Point of balance: 14 cm (5.5") beyond hand guard
Blade cross section profile: triangular with slight ground
Blade length wide profile: subtle inner curve at the middle of the blade and subtle upward tip.
Folded pattern steel: 1065 carbon steel + T8 tungsten-cobalt-vanadium high-speed tool steel.
Superior heat treatment: Hardness 58 HRC. Blade rebounds to true after 80-90
Asking for 200 USD + Shipping
This sword is still available
Now selling for 175 USD
