Forum Index > Historical Arms Talk > Weight of a 9mm cuirass? Reply to topic
Alexander H.
PostPosted: Tue 08 Sep, 2020 9:53 pm    Post subject: Weight of a 9mm cuirass?         Reply with quote
Hello, new member to the forum long time lurker.
So I been awfully curious as to how heavy a "bullet proof" curiass was compared to plate armor made before guns started dominating the battlefield. From what I heard, you would need at least 4mm of steel to have a hope of protecting you from a musket and I've heard claims that some historical curiasses could be as thick as 9mm.
I've been browsing some musuem sites that provided the weight of 3 quarter armor but they don't see to provide the armor's thickness. Would anyone happen to know how much a 9mm curiass would weigh and is there some some sort of mathematic formula you could use to determine a curiass based on its thickness?
Thanks in advance.
PostPosted: Tue 08 Sep, 2020 10:59 pm    Post subject:         Reply with quote
Cuirasses were only that thick across the chest. The thickness tapered off at the sides. It isn't possible to come up with a simple equation to determine the weight.
Here is a typical example. The breastplate is almost 9 mm across the chest but tapering down to around 6 mm at the shoulders and 3 mm at the sides. Weight is 7.5 kg (note that this isn't including a backplate).
http://www.allenantiques.com/A-209.html
Alexander H.
PostPosted: Wed 09 Sep, 2020 9:26 pm    Post subject:         Reply with quote
Thanks for the anserw. That's a lot lighter than I'd thought it be.
I found a video of people shooting at a 5mm-7mm, I wonder if a 9mm breastplate would be able to withstand some of the more powerful shots it failed to deflect.
https://www.youtube.com/watch?v=aGj0M-NJDGA&ab_channel=SylviaLeever
PostPosted: Thu 10 Sep, 2020 2:29 am    Post subject:         Reply with quote
There are at least three incidents of these breastplates stopping cannon balls.
Matthew Amt
PostPosted: Thu 10 Sep, 2020 4:31 am    Post subject:         Reply with quote
You might not think "light" if you had to wear something like that for a while... Razz
If the metal is the same, sure. All other things being equal, thicker is more resistant. Of course, 7mm of good steel will probably protect better than 9mm of plain iron, BUT there are a LOT of subtle variables!
Matthew
Tyler C.
PostPosted: Thu 10 Sep, 2020 7:09 am    Post subject:         Reply with quote
I don't have anything to add, but that's a great video! Thanks for sharing.
PostPosted: Thu 10 Sep, 2020 7:29 am    Post subject:         Reply with quote
Sylvia Leever has done some good research on this subject. Here is one of her papers:
Sylvia Leever, “For Show or Safety?” Arms & Armour, 3.2 (2006) pp. 117-125
Graham Shearlaw
PostPosted: Sun 13 Sep, 2020 12:20 pm    Post subject:         Reply with quote
Proof armour is a balance of more then just the metal's thickness or composition.
There the construction, its not uncommon for armours made of squares, scales or lamellar to have them pushed into the wearer's body.
The technical ability of time really matter, the entire Anima school of armour is born due to the problems with heat treating large plates to the newest stranded.
The later Duplex armours with the two layers of metal could easily have both a hard face an tough ductile layers.
The angle of the armour surface helps too, see the shift towards the pescod breastplate and its greater deflection angles.
Henry the VII's armours are a great look at how this change happened.
Martin Kallander
PostPosted: Sun 13 Sep, 2020 2:10 pm    Post subject:         Reply with quote
I thought lamellar was good because the plates would fly away when shot, taking the bullet with them
PostPosted: Sun 13 Sep, 2020 3:26 pm    Post subject:         Reply with quote
Nope. The best bulletproof armour until the invention of aramid was steel plate. Ideally, one made with differential hardening but that was difficult to do so they compromised with duplex and triplex constructions.
Graham Shearlaw
PostPosted: Sun 13 Sep, 2020 3:49 pm    Post subject:         Reply with quote
The plates are just torn free an carried in to the wound.
https://www.youtube.com/watch?v=OSxFY917UH8
Don't feel to bad about it lots of WW1 armour was made up from small plates.
Martin Kallander
PostPosted: Mon 14 Sep, 2020 3:31 am    Post subject:         Reply with quote
Graham Shearlaw wrote:
[quote="
Huh, that was the video I got the idea from. My memory of it has really warped over time.
