What are the pros of an inflatable siege ladder?
Heron of Byzantium put a lot of effort describing this rather peculiar device in his treatise on sieges but he didn't say anything about why one should make a ladder out of leather and then inflate it to scale a wall instead of just using a normal ladder.. What do you guys think are the pros of this kind of siege engine compared to wooden ladders aside from being easier to bring along with an army?
 Attachment: 531.2 KB
Also interesting is the use of a net to scale the last part of the wall instead of just making the ladder longer. Although it could be that an inflatable ladder isn't strong enough to be longer than a certain length the Heron also advices you to do this w [ Download ]
I think the sturdier the ladder, the quicker it would be to climb it, and the larger the chance of success.
If it were even possible to make a leather ladder so that it is more or less air tight, it would still be really hard to climb one. Let alone when the enemy would be shooting at you.
I don't think we should dismiss historical texts like that, especially not manuals like this one which was specifically made to inform actual soldiers on how to conduct siege warfare. Making a ladder out of leather is clearly more labour intensive than wood so they clearly wouldn't do it if it didn't work. In spite of that, Heron includes this contraption in a text that is supposed to teach very little above the basics of siegecraft.
For ease of reference, the text runs
Making ladders of hides we shall bring them to the wall; these are stitched like wineskins and, smeared around the stitches with grease, f illed so as not to def late. For when they are inf lated and full of air <and> kept from def lating, they necessarily become upright, held f irm for climbing by the air. But if the wall should be higher than the ladders, they are placed beneath ladders of tow which are constructed by being bound together with plaiting and stitching, net-like, similar to the so-called soldiers’ packs. Hooks are attached to the ends of these <nets> so that when thrown from the leather ladders placed beneath, they catch on the merlonsand thus facilitate the ascent of the wall at will. The drawings of the ladders are delineated
We should also be cautious that the treatise here is referencing a far earlier work by Philo Mechanicus, so the invention may not be a current weapon but referencing experiments of a great engineer known for work on pneumatic and hydraulic devices.
Re: What are the pros of an inflatable siege ladder?
OK, now try to imagine a ladder using moderm and airtight/water tight rubber with perfectly sealed seams, inflate it to the enormous pressure it would take to make it rigid enough for one person to climb on it without it probably not folding under localized pressure on one of the rungs ? I don't have the answer if this would even be possible with just a short ladder, much less a 30 foot ladder and a dozen guys trying to climb the rubber ladder while opposed by people on the battlements shooting sharp objects at the people " climbing " ( Trying to climb ;) ) and probably making holes in the rubber letting the air or water out of it !
Now, lets imagine the same with leather with less than perfect seams, the leather not being 100% water resistant and getting softer and losing it's shape due to being soaked !?
I sort of see this as imaginative but impractical ideas that sounded good in theory in a period treatise to impress a possible rich patron, maybe based on some much older texts subject to interpretation ?
As someone suggested this could have used some sort of hydraulic or pneumatic device inflated to extend but with some rigid parts locking in place after the contraption was fully pressured ? So, not 100% impossible, but would be an engineering nightmare prone to failure and probably very expensive to make and maintain in working condition.
I can see this type of " Information " in a period treatise to be similar to the " Unscrew the pommel Meme " or the inventive ahead of there time designs by Leonardo Da Vinci of flying objects, and tanks propelled by the crew inside it with hand cranks !?
Just giving this Topic a bit of healthy skepticism without dismissing it out of hand, it doesn't seem like something that would have worked well, or at all in actual use.
Now, just for fun how could this work:
A) The rungs would be rigid wooden ones.
B) Inflating the leather would unfold it and extend it to it's full length.
C) The now fully extended inflatable ladder would have hooks at the top to grab onto the battlements so the ladder would be in tension when people ascend the ladder and not supporting their weight in compression.
So in a way it's would be like " Pushing A Rope " sort of thing just to get it long enough to hook onto the battlements.
But normal ladders would be easier to make, and if they had to be made portable for transport easier to have the ladder mades into sections that could be added as needed to make a longer and longer ladder.
Past a certain length siege ladder become impractical, and some sort of more solid version built into a siege tower is needed against very high defended walls: The siege tower also can protect the climbers from arrows until the reach the top of the siege tower , covered with wet hides to protect the siege tower from fire.
An inflatable siege ladder?
Can you see the people on it bouncing around and struggling to stay steady as bags move an wobble.
It'd be like something out of a game show.
That's before we get to the wear an tear on from men in armour climbing all over it and when some one will throws, shoots or drops something sharp it will pop the lot of them.
Really why not use large wicker baskets an stack them up? they could be solid and light enough to carry to the wall an climb quickly.
Various interesting designs for collapsible ladders do seem to have been a common feature of late medieval/early modern "war books", although I can't say I've come across an infatable one before.
http://manuscriptminiatures.com/5728/21010/
http://manuscriptminiatures.com/5728/21009/
https://i.imgur.com/wzyzydx.gif
On the other hand, there are examples of leather being used to create air-tight, inflatable devices. Here's Peter Whitehorne's description of an inflatable girdle, which is very similar to devices illustrated in a number of 15th century manuscripts:
https://i.imgur.com/2diYbTb.png
I'll have to double check but i think Pietro Monte even uses a similar language of "stiched together like wineskins" as your source when describing his floatation device.
That said no I'm not quite sure what the advantage of an infatable ladder would be. My only guess would be that after being inflated the advantage would be it's rigidity over just a collapsible rope ladder. You would probably need somone with some pretty strong lungs to get it rigid enough to actually support someone's weight. Though it might be like jean suggests that the idea was that it just had to be rigid enough to push a hook up to the top of the wall, and afterwords would just be supported by tension like a rope ladder.
Edit: just noticed your attachment. huh, he's definitely standing on the top rung of a leather ladder. i guess we'll have to go with the strong lungs theory.
While we should be careful when considering whether or not a source like this is credible in regards to if ladders like these were used, I think it should also be noted that there is a consistent pattern in the tactica genre where if something cool from antiquity is written down but is not actually used by the medieval romans, then they say that it is so in no unclear terms. As an example, the ST describes ancient formations but then say that those are no longer used and Heron also says this about the ram of Hector as well if I recall correctly. So the fact that he doesn't say anything of the sort about this ladder is a strong indicator that it actually was used.
It should also be noted that these ladders being invented in antiquity but allegedly seeing use into the 10th century could just as easily be interpreted as evidence they worked.
