15th (ish) century crossbow!
Hi gang- Iím pretty jazzed about this: Iíve just competed my second crossbow; itís a vaguely 15th century central European bow with a flat self-prod of ash. The draw weight is 100lbs, with a 25cm draw, and 20cm power stroke; about 750 inch-pounds of power. It was pretty nerve wracking tillering the prod; I had 2 that exploded, then I realized it would help to steam and bend in a little deflex first. It shoots well and HARD, with even a bit of recoil. The tiller is maple and the tickler is also ash; the nut and inlays are all black walnut.
 Attachment: 135.37 KB
 Attachment: 114.64 KB
That's a lovely crossbow - I will state that you have rather strong nerves to make the nut and trigger out of wood!
Thank you! Relooking at those photos, I realize the bridle looks pretty anemic so Iím going to redo it.
The 100 lb draw is well within the limits of the walnut nut, and I constructed the ash tickler (!) in such a way that the wood grain is oriented optimally for the load at each point. But itís a fair point; I donít think I would go much above 150 lbs with those components still of wood.
Iím very interested in the load limits of a self-prod with rectangular cross-section. I think the deflex is a critical part of this, so the next one I do Iíll aim for higher weight and more deflex steamed in.
