Harry Marinakis
Posted: Fri 26 Jul, 2019 2:33 pm Post subject: Bauernwehr & byknife |
I went out of my comfort zone and made a bauernwehr with a byknife and pricker. I made this as a gift for a friend.
The bauernwehr and byknife were forged from O-1 tool steel. The guard, nagel, and pricker were forged from mild steel.
The grip scales are Red Deer antler.
It's a bit rough, as I was pressed for time, and I couldn't spend the time that I wanted to get it nice and clean. The leather sheath, in particular, is pretty bad. I screwed up the tip so badly that I had to cover it up with a chape. I used mild steel sheet for the chape, which was fabricated in a traditional medieval fashion. But learned a lot from this experience, and look forward to trying it again with some new ideas.
I am particularly interested in how other have fabricated the out layer than holds the byknives. I sewed an inner layer of leather around the blade, then added two thin sheets of 1/32" Birch for some stiffness.Then I sewed an outer layer of leather around the entire sheath. Finally, I added one more layer of leather for the byknife and pricker. So, in actuality, the lower half of the sheath has 3 layers of leather and a strip of Birch.
Attachment: 85.47 KB
Attachment: 87.28 KB
Attachment: 90.07 KB
Attachment: 77.74 KB
Ian Hutchison
Posted: Mon 29 Jul, 2019 6:54 am Post subject: |
Very nice job Harry, I think it looks great, don't see anything that looks 'rushed'.
Harry Marinakis
Posted: Mon 29 Jul, 2019 7:59 pm Post subject: |
Thanks Ian. But if you look at my last photo, you can see where the parts of the bolster don't mate cleanly. That's just one of many problems.
Sean I like your idea. Thanks, I'll have to play around with that method.
Radovan Geist
Posted: Mon 29 Jul, 2019 9:40 pm Post subject: |
The whole set looks nice! I did the same as Mr Flynt. The area just above the mouths of the internal sheaths can get tricky and wrinkle, depending on the size / thickness of the side-knifes, but if you soak leather well it should work.
Ian Hutchison
Posted: Tue 30 Jul, 2019 5:04 am Post subject: |
Harry Marinakis wrote: | Thanks Ian. But if you look at my last photo, you can see where the parts of the bolster don't mate cleanly. That's just one of many problems.
Sean I like your idea. Thanks, I'll have to play around with that method. |
Hey, I bet you will see that on some originals too!
Antal László
Posted: Tue 30 Jul, 2019 5:29 am Post subject: |
I've never made a sheath so I can't give advice but I think that looks great! What a brilliant gift! When you make something yourself then the tiny mistakes you made will always scream at you but I think this looks great.
