Alex Indman
Posted: Mon 04 Feb, 2019 2:33 pm Post subject: Ideas on alternative mounting of a Scottish Dirk blade? |
I just got one of these blades: https://www.atlantacutlery.com/scottish-dirk-blade-blanks to use in a DIY project eventually.
This is one of the surplus/discontinued blades Atlanta Cutlery is now selling. Actual dimensions are 12 1/4" long blade, 1/4" thick at the base. Pretty good quality for the price, filework particularly looks great.
I really liked the blade when I saw it, and decided that at this price it makes sense to just buy it and then figure out how to mount it. The catch is that I don't like proper Scottish Dirk handles at all!
Can you think of some kind of different "plausibly historical" handle style for this kind of blade?
I was thinking about something like early bollock dagger, or maybe rondel dagger handle. Don't see these as quite the right match for the blade in my mind, though.
So far I am leaning toward some purely "fantasy" handle, with no historical pedigree. Something with small guard/pommel, suitable for both forward and reverse grip, simple lines but with some decorative materials to keep up with the filework on blade.
My current project will probably keep me occupied for a couple months at least, so I have time to consider design for the Dirk blade. Any ideas are welcome in the mean time!
Norman McCormick
Dan D'Silva
Posted: Tue 05 Feb, 2019 8:28 am Post subject: |
Dang, I ordered one of those too, but they sent me a different one that was much thinner. You may have gotten the last one
I'm planning on one of those Lowland dirks once I get a suitable blade. Apparently they were known as "whingers."
Alex Indman
Posted: Wed 06 Feb, 2019 6:31 am Post subject: |
Hey, these are great replies!
Sean, I don't think your "Colonial American knife forms" would work well with this blade. Simply because they require handle to be located up towards the back of the blade rather than on center line where the Dirk's tang is.
But the "whinger" idea is just what I was looking for!
Somehow I never heard of this type at all. The pictures in the linked topic are very informative, including scabbards/suspension/by-knives/etc. I will probably end up mounting it in this fashion, with mild steel fittings and black wood for grip.
There is only one detail I am not happy with - all the "whingers" pictured seem to have round grips, which isn't good for edge alignment. On a blade like this, wide enough for effective cutting, I would consider edge alignment an important consideration.
Do you think making the grip octagonal or at least oval in cross section would be too much out of character?
Posted: Wed 06 Feb, 2019 7:06 am Post subject: |
I wouldn't hesitate to use a chamferred rectangle or other faceted shapes on a knife of that period. As you see, there are many variants of material and construction, including the relatively weak half-tang design. The Whinger appears to be an artistic nod to the old ballock/dudgeon family, but with the tastes of the early 19th c. You wouldn't be treading on any historical graves by adapting it.
You could use a turned tool handle as-is or rasp/sand flats or facets as you wish. https://www.ebay.com/i/153244984611?chn=ps
Keep in mind, too, that a centered tang doesn't have to go through the dead center of the handle. For that early American knife I posted, you could locate the tang hole off center towards the back of the blade. There's a limit to that, but I think you could get enough offset for it to look right with a guard.
Alex Indman
Posted: Wed 06 Feb, 2019 7:36 am Post subject: |
Sean Flynt wrote: | ... The Whinger appears to be an artistic nod to the old ballock/dudgeon family, but with the tastes of the early 19th c.
you could locate the tang hole off center towards the back of the blade. There's a limit to that, but I think you could get enough offset for it to look right with a guard. |
Actually the Whingers published in the linked topic are dated 16th-17th c., so the type isn't a 19th c. artistic invention.
I played with measurements for offsetting the tang on this blade myself, but concluded that to make it work either the tang would have to be narrowed down way too much, or there would be almost no handle material left at the bottom edge of tang. So for me at least it didn't work out.
