Forum Index > Off-topic Talk > CCB 46 Vintage Machete - Help to Identify Reply to topic
Dorel Corel
PostPosted: Thu 15 Nov, 2018 12:03 pm    Post subject: CCB 46 Vintage Machete - Help to Identify         Reply with quote
Dear Colleagues,
Please help me with some advices.
I just bought this Machete. It has a engraved "CCB" and the number "46"
Can you please look at the pictures and tell me your opinion about this model ( dating, value and other characteristics )
Thanks for helping me with these answers !
Dorel Corel
PostPosted: Sun 25 Nov, 2018 10:46 am    Post subject:         Reply with quote
What can "CCB"mean ?
PostPosted: Sun 25 Nov, 2018 2:34 pm    Post subject:         Reply with quote
My guess is that it was originally a sword that had been broken at some stage of its life. It was subsequently recovered, ground to shape, and had that grip added to it.
Dorel Corel
PostPosted: Fri 07 Dec, 2018 3:43 am    Post subject:         Reply with quote
The person who sold me this macete, told me it can be from Indonezia/Philippines ...
PostPosted: Fri 07 Dec, 2018 6:19 am    Post subject:         Reply with quote
That blade has been ground down from something else; it wasn't originally made like that. It should be decent steel if it was originally a longer sword but it wouldn't make a good machete because the balance looks off. I can't think of a use for it off the top of my head. To function as an effective machete it either needs to be longer or to be wider at the tip.
PostPosted: Fri 07 Dec, 2018 6:58 am    Post subject:         Reply with quote
The bend near the tip is puzzling if it came from most swords ? That is unless the blade was reworked at the forge and that bend hammered in for some reason and re-heat treated ?
Could be a butcher knife ? CCB could be someones initials, could be the maker's mark and 46 might mean that someone made at least 46 knives.
Maybe forged from a leaf spring ? In any case it's somewhat crude but probably functional if well heat treated ?
Anything crudely made in a small shop is not something of a pattern easily identified.
PostPosted: Fri 07 Dec, 2018 7:01 am    Post subject:         Reply with quote
Could be a butcher knife ? CCB could be someones initials, could be the maker's mark and 46 might mean that someone made at least 46 knives ?
PostPosted: Fri 07 Dec, 2018 7:07 am    Post subject:         Reply with quote
The initials combined with the number suggests that it was originally part of a mass-production run for the military.The shallow fuller and the position of the number suggests that it was originally a lot longer than it is now.
It is hard to tell but I think the fuller looks like this.
If true, then the blade was broken and reground. I think it was originally a cavalry sabre or perhaps a naval hanger. It isn't worth anything unless it has a special story tied up with its provenance or it originally belonged to someone famous.
