Forum Index > Off-topic Talk > Test cutting Aquatherm 2.5cm diameter PPR pipe Reply to topic
Lancelot Chan
PostPosted: Sat 04 Aug, 2018 10:11 am    Post subject: Test cutting Aquatherm 2.5cm diameter PPR pipe         Reply with quote
This is the exact PPR pipe Peter Johnsson suggested as a simulator for upper arm bone. Here's my take on cutting these "upper arm" target with Longship Armoury 3V swords.
https://www.youtube.com/watch?v=MLWuoV5JOuw
Ancient Combat Association http://www.acahk.org
Realistic Sparring Weapons http://www.rsw.com.hk
Nightstalkers http://www.nightstalkers.com.hk
Lancelot Chan
PostPosted: Wed 08 Aug, 2018 7:05 am    Post subject:         Reply with quote
https://youtu.be/R6I20yFXpuw
Cutting with a Lung Chuan "broad blade" katana that I experimented a new finishing sharpening grit with.
Lancelot Chan
PostPosted: Tue 14 Aug, 2018 1:55 am    Post subject:         Reply with quote
https://www.youtube.com/watch?v=WkuWnHgXciU
This is not the aquatherm pipe but 2 china ppr pipes to simulate the aquatherm difficulty. I tried to cut it with a lightweight short bastard sword by atrim.
Lancelot Chan
PostPosted: Wed 22 Aug, 2018 3:02 am    Post subject:         Reply with quote
https://youtu.be/AudY5E_CzhU
Test cutting 3 PPR pipes cored thigh diameter newspapers roll at thigh height with Longship Armoury 5160H DS Dadao.
Michael P. Smith
PostPosted: Wed 22 Aug, 2018 6:57 am    Post subject:         Reply with quote
Thanks for posting these, Lance. I may try to construct such a target.
Lancelot Chan
PostPosted: Wed 22 Aug, 2018 7:06 am    Post subject:         Reply with quote
Thanks for watching. Big Grin Not many people are interested in my videos I guess.
Lancelot Chan
PostPosted: Thu 30 Aug, 2018 2:11 am    Post subject:         Reply with quote
https://youtu.be/ntSbMCjJtKQ
Testing the shorter cuts with Longship Armoury 3V Tengu on 2 ppr pipes cored upper arm newspapers roll target.
Lancelot Chan
PostPosted: Wed 05 Sep, 2018 8:09 am    Post subject:         Reply with quote
https://youtu.be/Cs728Kh_Jok
Longship Armoury 5160H DS Dadao short cuts vs twin PPR pipes cored upper arm difficulty newspapers roll.
Justin H Nunez
PostPosted: Wed 05 Sep, 2018 11:19 am    Post subject:         Reply with quote
Not so. I always try to watch. I find them informative and it's good to just watch someone having fun with their swords. I was thinking it would be interesting to see how things cut if the cuts were delivered from more of a "fighting type" sequnece instead of a stationary test cut dedicated stance.
Nothing in fencing is really difficult, it just takes work.
Lancelot Chan
PostPosted: Wed 05 Sep, 2018 11:32 am    Post subject:         Reply with quote
Well, I did plenty of those in the past, like moving cuts, running cuts, spinning cuts, deflect first and then cut.
The short cuts I did recently were also the fighting type. In fact it's the stance I used in sparring, though it may not be familiar to you. I attached screen captures to show. Even the big cuts were used in the sparring too.
 Attachment: 37 KB
 Attachment: 56.6 KB
Lancelot Chan
PostPosted: Wed 05 Sep, 2018 11:44 am    Post subject:         Reply with quote
This is where the short cut was put to use.
Lancelot Chan
PostPosted: Wed 05 Sep, 2018 11:56 am    Post subject:         Reply with quote
This one shows the big cut + short cut combo.
Short cut after a series of exchanges.
And this was the big cut in the fight.
Lancelot Chan
PostPosted: Thu 06 Sep, 2018 8:50 am    Post subject:         Reply with quote
These are the application of the horizontal / upward cuts I did in test cut.
