Forum Index > Historical Arms Talk > What Do I have? Reply to topic
Jason McEntee
PostPosted: Wed 08 Jan, 2014 11:19 am    Post subject: What Do I have?         Reply with quote
Last year my father-in-law gave me what apears to be an antique sword of some kind...but I have no idea what it is. Some folks on SBG said perhaps a Persian Quadara or a variation of a Russian Kindjal, but I've not been able to confirm this. Has anyone here seen one of these before? I'm very curious about the history of this type of blade. Thanks for looking...
"You see, a sword is three feet of tempered steel---with death dancing on every inch, and hanging like a dark star on the very point."
--Ronald Lacey, as Oswald, from Sword Of The Valiant, 1984
Jason McEntee
PostPosted: Wed 08 Jan, 2014 4:04 pm    Post subject:         Reply with quote
A couple more pics...
Eric S
Reading list: 8 books
PostPosted: Wed 08 Jan, 2014 4:11 pm    Post subject: Re: What Do I have?         Reply with quote
I believe the correct term is "bebut" (curved kindjal), most probably Russian.
https://www.google.com/search?q=bebut+sword&safe=off&rlz=1C1CHFX_enUS460US460&espv=210&es_sm=122&source=lnms&tbm=isch&sa=X&ei=ievNUt6BB6by2QXlh4GwDA&ved=0CAkQ_AUoAQ&biw=1526&bih=814
Jeroen T
PostPosted: Wed 08 Jan, 2014 10:00 pm    Post subject:         Reply with quote
I too believe it's a kindjal.
I haven't seem one with such a blade but i like it very much, great find.
David Lewis Smith
PostPosted: Thu 09 Jan, 2014 7:17 am    Post subject:         Reply with quote
I have one of these in my collection, it is a very good find on your father in laws part. It is not so much 'Russian' as it is from the Caucasus and Black Sea area
David L Smith
MSG (RET)
Jason McEntee
PostPosted: Thu 09 Jan, 2014 11:30 am    Post subject:         Reply with quote
Interesting, thanks. I can't find much info on these...one site said they were carried by Cossacks? If I was to guess, I'd say 19th to perhaps early 20th century? What do you know about yours David, and how did you come across it?
Norman McCormick
PostPosted: Thu 09 Jan, 2014 12:16 pm    Post subject:         Reply with quote
Hi,
Net search for Quadara/Quaddara will give you info re this type of weapon. Hope this is of help.
Norman.
Timo Nieminen
PostPosted: Thu 09 Jan, 2014 3:30 pm    Post subject:         Reply with quote
Quaddara (with variation in the spelling) is the Persian/Iranian name.
Bebut is, AFAIK, the Azeri name. They're quite common in Azerbaijan (or, at least, used to be).
In Russian, they are usually called kindjal (which is also used for the straight double-edged blades).
So, perhaps, if you want to know the "proper name", it is necessary to know the region of origin.
There might be naming differences for the curved double-edged blades and the curved single-edged blades (single-edged, neglecting a short back edge). The Russian military ones are double-edged (unless I'm confused by bad replicas), which are often called "bebut" to distinguish them from Russian military straight kindjals.
Some further discussion of these, and similar, swords:
http://www.swordforum.com/forums/showthread.p...e-of-Sword
http://www.swordforum.com/forums/showthread.p...nd-kindjal
http://www.vikingsword.com/vb/showthread.php?t=2528
http://www.vikingsword.com/vb/showthread.php?p=58614
David Lewis Smith
PostPosted: Thu 09 Jan, 2014 6:11 pm    Post subject:         Reply with quote
Go with what Manoucher says as far as names. He really is the expert.
I will try to take some photos of mine to post, work depending. I cannot tell you much about mine. Unlike the bulk of my collection that was bought in the middle east this one was bought at a gun show in Fayetteville North Carolina.
David L Smith
MSG (RET)
Jason McEntee
PostPosted: Fri 10 Jan, 2014 2:06 pm    Post subject:         Reply with quote
Timo, thanks for the links. I'll check'em out when I'm off work.
@ David, I look forward to seeing pics of yours. Happy
Jason McEntee
PostPosted: Sun 09 Feb, 2014 12:18 pm    Post subject:         Reply with quote
The other day my Father-in-law asked me to bring the piece to his house so he could look it over. He said he new some key things to look for to see if it is authentic. When I handed it to him, he immediately looked at the back of the scabbard's chape. After a few seconds, he said, "reproduction."
He pointed out a solder joining the chape together, and said if it was an actual antique it would not be soldered. Was his assessment correct? See below...
Norman McCormick
PostPosted: Sun 09 Feb, 2014 2:10 pm    Post subject:         Reply with quote
From what I can see on the photographs, NO.
Chris Goshey
PostPosted: Sun 09 Feb, 2014 2:35 pm    Post subject:         Reply with quote
I agree with Norman, soldering has existed since at least 3000 BC and would have been available to an inhabitant of the Caucasus mountains in the 18th-20th centuries.
One correction I might make in terms of its name, a better pronunciation/transliteration of the Russian term is "kinzhal" as it is spelled кинжал in Russian and the ж character is pronounced "zh." According to my girlfriend, who is a native Russian speaker, the word means any dagger not just ones from the Caucasus.
Johan Gemvik
PostPosted: Sun 09 Feb, 2014 2:50 pm    Post subject:         Reply with quote
If that's a reproduction it's the kind I'd like to own. Wink
Very handsome blade.
Jason McEntee
PostPosted: Sun 09 Feb, 2014 4:10 pm    Post subject:         Reply with quote
Good news indeed, thank you gentlemen! Happy
Timo Nieminen
PostPosted: Sun 09 Feb, 2014 6:07 pm    Post subject:         Reply with quote
Soldering is an old technology, perhaps 6000 years old already. So soldering (and brazing) don't mean "modern". (The particular solder alloy might.) Also, the reproductions I've seen haven't had solder seams like that.
It's probably a repair (and could be a modern repair). Scabbards get recovered, replaced, etc., and sometimes the old scabbard fittings suffer in the process. The suspension ring mount is a different metal from the rest of the scabbard mounts? Could be mix-and-match scabbard parts.
L. Smith
PostPosted: Sat 17 Dec, 2016 4:52 pm    Post subject:         Reply with quote
Russian Imperial issue Model of 1907 issued to artillery and machine gun crews. One of the last attempts to use swords as combat weapons. When the Bolsheviks took over they discontinued it as military issue.
Originals have proof marks on blade and scabbard.
Timo Nieminen
PostPosted: Sun 18 Dec, 2016 3:48 am    Post subject:         Reply with quote
The 1907 bebut is different. Double-edged diamond section blade with narrow fullers next to the central ridge, different hilt, different scabbard. An example, from http://www.sailorinsaddle.com/product.aspx?id=832
