Description:
(translated by me and google translate)
DIMENSIONS
Length : 2245 mm
Width: 225 mm
Length :blade 417 mm
Weight : 2101 g
Straight stabbing point of diamond cross section and rectangular base . Ax blade with convex edge and pointed ends . The edges extended to a low point. The hook pointed with a straight bottom and sloping upper side . The point of the hook wider and closest quadrilateral . At the cross a side tip, 41 mm long and quadrilateral . On the opposite side a threaded hole . Open socket in the form of two wider rails , L 120mm , fastened with two rivets continuing in 520 mm long, narrow rails with pointed end . Originally attached with five rivets each ( three missing) . This is also posted on the armsandarmour forum.
Pollaxe - picture from the museum
More pictures from the museum
Regards
Kim
*edit : sorry for the bad links, better pictures added,
