Forum Index > Historical Arms Talk > Earliest mention of enclosed helms? Reply to topic
Mario M.
PostPosted: Sat 18 Jun, 2016 6:51 am    Post subject: Earliest mention of enclosed helms?         Reply with quote
Greetings,
I have been searching for the earliest mention of enclosed helms being used in Europe.
The earliest one I found was the famous account from 1177 at the tourney at Pleurs, when William Marshal is recorded as having his head on an anvil while the smith cuts and hammers his battered helm into shape so he can take it off.
Does anyone else have any other source candidate?
Also, I do find it weird that, regardless of that account, the vast majority of pictorial depictions stay faithful to the good ol' simple nasal helm for quite a while, a few to even several decades after this recorded usage of a (somehow)enclosed helm.
“The stream of Time, irresistible, ever moving, carries off and bears away all things that come to birth and plunges them into utter darkness...Nevertheless, the science of History is a great bulwark against this stream of Time; in a way it checks this irresistible flood, it holds in a tight grasp whatever it can seize floating on the surface and will not allow it to slip away into the depths of Oblivion." - Anna Comnena
Craig Peters
PostPosted: Sat 18 Jun, 2016 9:25 am    Post subject:         Reply with quote
Does Marshall's helmet need to have been a form of great helm to have been stuck to his head? This image from the Rolandslied of Konrad Pfaffe shows an unusual helmet that's not really an enclosed helm, but vould feasibly become stuck to the head:
http://manuscriptminiatures.com/media/manuscr.../427-2.jpg
Also, it could well be that a badly dented or deformed nasal helmet could be stuck to one's head.
Tom King
PostPosted: Sat 18 Jun, 2016 9:43 am    Post subject:         Reply with quote
I'd hazard to guess that william marshal was wearing a precursor form like above, dated to 1207. True great helms don't really pop up until the mid 13th century.
Mario M.
PostPosted: Sat 18 Jun, 2016 10:32 am    Post subject:         Reply with quote
I do not believe any of the designs you presented could explain the event described at the tourney.
In order of a skullcap to be stuck on the head, it would require it to be crushed into the skull or facial bones.
What William was wearing must have been a helmet that encased the head and was dented beneath the widest radius of the skull, anywhere from the ears to the neck.
I am not speaking of great helms, but enclosed helms;
https://en.wikipedia.org/wiki/Enclosed_helmet
Richard is depicted as wearing one in his second seal;
Here are the seals of Henry;
These are merely two decades away from the events depicted at the tourney.
Mart Shearer
PostPosted: Sat 18 Jun, 2016 1:38 pm    Post subject:         Reply with quote
L'Histoire de Guillaume le Marechal was written after his death in 1219, at the bequest of his son. Is the description accurate for the date of the event, or a reflection of current equipment, as is the case in manuscript miniatures?
Mart Shearer
PostPosted: Sat 18 Jun, 2016 2:02 pm    Post subject:         Reply with quote
The Fokker D.VII was flying a mere two decades after 1898. Are we to assume there were flying aeroplanes in the late 1890s?
Mario M.
PostPosted: Sat 18 Jun, 2016 2:13 pm    Post subject:         Reply with quote
It is a description of an event that happened in 1177, what would be the purpose of including such an event in a biography if it did not happen?
I was merely pointing out that I do not mean the greathelms of the mid 13th century onwards, but the earlier enclosed helms such as these;
http://manuscriptminiatures.com/4885/14173/
You also ignore that I have a written source at least implying the existence of such helms in 1177, it is not like I am basing this on later imagery alone.
PostPosted: Sat 18 Jun, 2016 4:01 pm    Post subject:         Reply with quote
The text says that the helmet was damaged in such a way that it couldn't be removed. It doesn't imply a fully enclosed helmet.
Mart Shearer
PostPosted: Sat 18 Jun, 2016 6:38 pm    Post subject:         Reply with quote
Not at all. We have medieval written histories (the Weltchronik springs to mind) which describe older events in contemporary ways. It's not unrealistic in the medieval way of thinking. For instance Wycliffe's 14th century translation of the Bible has Goliath in " a brasun basynet on his heed". I doubt the ancient Philistines had bascinets.
On the issue of images, here's an 1899 image of what a futurist imagined life in the year 2000 would look like. Sadly, such fighting machines weren't that far away, though they were still not available in 1899.
My point being that a medieval history written in 1220 would not be unusual in applying current modes of dress, equipment, or practices to an event which occurred 50 years earlier.
Perhaps the Old French original passage might shed some light on the matter. Isn't this the tournament where the judges were trying to present a big fish?
Mario M.
PostPosted: Sun 19 Jun, 2016 3:52 am    Post subject:         Reply with quote
Alright, I would like anyone to propose in what possible way a nasal helm or a helm with just a faceplate would be bent to result in it being stuck on someones head.
It makes no sense.
You can argue that the passage is a 13th century invention and that it did not happen in 1177(something I also doubt, it being a biography and the event itself being a useless addition), but I can not see how could a non-enclosed helm bent in a way to remain stuck on someones head.
PostPosted: Sun 19 Jun, 2016 4:33 am    Post subject:         Reply with quote
A standard bascinet can be stuck on your head if it is deformed.
Craig Peters
PostPosted: Sun 19 Jun, 2016 4:35 am    Post subject:         Reply with quote
Mario,
It could also be that the tourney happened at an entirely different date than the one given in the manuscript. For instance, what if the tourney where Marshall's helmet became stuck was in 1207? The History of William Marshall was written no earlier than 1220, and possibly later. It would not be that terribly difficult to confuse one tournament with another. If the real tourney was in the early 13th century, William could have easily been wearing an early great helm.
Alternatively, since the poem was meant to provide a flattering depiction of Marshall, it's possible the poet could have invented the incident to show how doughty his hero is. Personally, I don't like assuming that an incident was invented, but it certainly is possible.
Either of these explanations could account for the incident without assuming that early great helms exist in 1177, when there is no other evidence to support it.
Craig Peters
PostPosted: Sun 19 Jun, 2016 4:37 am    Post subject:         Reply with quote
Out of curiousity Dan, on what basis do you make this claim?
Mario M.
PostPosted: Sun 19 Jun, 2016 4:39 am    Post subject:         Reply with quote
...how?
Also, we are talking about 12th century helms here.
Craig Peters wrote:
Mario,
Yes, I already accepted that possibility, read my last post.
PostPosted: Sun 19 Jun, 2016 5:05 am    Post subject:         Reply with quote
Crush the plate down near the jaw and neck and you can't take it off.
Mario M.
PostPosted: Sun 19 Jun, 2016 5:33 am    Post subject:         Reply with quote
As possible or how likely/unlikely that is, how would you use that same example to a pre 13th century nasal helm, with or without a faceplate?
PostPosted: Sun 19 Jun, 2016 6:41 am    Post subject:         Reply with quote
Does it matter how likely it is? It only has to happen once for it to be mentioned in an account. in fact is it MORE likely to be mentioned if it wasn't a common occurrence.
Mario M.
PostPosted: Sun 19 Jun, 2016 7:09 am    Post subject:         Reply with quote
You lost me here.
By that logic an ordinary iron skullcap could also be a candidate since it being dented in some sort of impossible manner would also then be written down.
The event debatably happened in 1177 and was written down in the early 13th century.
So if you are arguing that did not needed to be an enclosed helm, the alternative for the timeframe is a nasal helm of some sort.
I really do not see how a nasal helm would result in Williams anecdote.
Craig Peters
PostPosted: Sun 19 Jun, 2016 8:16 am    Post subject:         Reply with quote
What we need is someone who's prepared to sacrifice a nasal helmet for an experiment, plus a swordsman with a reasonable replica sword appropriate to the later 12th century, and a dummy with a human head that fits the helmet...
Mario M.
PostPosted: Sun 19 Jun, 2016 9:10 am    Post subject:         Reply with quote
"With this, they left the lodgings and came to the forge, where they saw him with his head on the anvil. It was no laughing matter, far from it, for the smith with his hammers, wrenches and pincers, was going about the task of tearing off his helmet and cutting through the metal strips, which were quite staved in, smashed and battered. The helmet was so tight around his neck that it was freed with great difficulty. Once the helmet was prised off – and it was pulled off with great difficulty – the knights who had come to the forge greeted him graciously"
That settles the debate on whether it was enclosed or not.
Which does not erase the argument pointed out that it might not have happened in 1177, but I believe it did.
So, in case of actual physical proof, the seals I provided from the 1190s are indeed the earliest examples of enclosed helms so far?
Nobody has anything earlier to provide? Worried
