Hector A.
Posted: Wed 07 Jan, 2015 3:10 pm Post subject: |
Didn't have time to answer in full last time.
Like i said before not using a slack belt sander is pretty crazy in terms of time consumption and edge quality (i wont go into detail), but if you want to regardless then the best method to sharpen a sword if your a newb or noob at it ^^ is a spiderco sharpmaker, it will be infinitely easier to use than free hand stones and will do a good job on most swords, the angle you should use is 40 degree's, don't use the SC however on thick swords like XVa's,XVII, XVIIIb, XVIIIe etc... they have far greater angles than 40 degree's and it will take ages to sharpen one and all in all it won't be the right angle for such a sword, so use it on thin swords, even if the angle is not exactly 40 degree's it will reform one relatively quickly.
Ben: Modern clothing is mostly cotton and polyester, those are easy to cut starting at 600-800 grit . Linen requires 1200 grit + stropping to cut effectively, ask around this forum, people who have cut linen will not have found it very effective below this threshold, and i would argue that 1200 is still not enough for linen as it lacks consistency.
Also to who ever brought it up, even a really poor 80 grit edge can cut paper... cutting paper is nothing impressive and definitively not overkill... lol, its the bare minimum, it means both planes of your edge meet, that's it... nothing special or magical about it.
Mike Ruhala
Posted: Wed 07 Jan, 2015 5:08 pm Post subject: |
Does your Constable have much distal taper?
Usually at HEMA cutting tournaments the loaner sword is a Crecy. I like the Crecy, it's a good sword that can perform all the cuts... I just wish it were scaled up to the Baron's size or just a little larger, art suggests XVIa's like that were used into the 16th c.
Hector A.
Posted: Thu 08 Jan, 2015 4:37 am Post subject: |
Mike Ruhala wrote: | Does your Constable have much distal taper?
Usually at HEMA cutting tournaments the loaner sword is a Crecy. I like the Crecy, it's a good sword that can perform all the cuts... I just wish it were scaled up to the Baron's size or just a little larger, art suggests XVIa's like that were used into the 16th c. |
Constable doesn't have much distal taper, but it does flatten out at the COP very aggressively because getting thicker once more at the point.
ps: I like how we are helping each other on swords, u on the viceroy me on the constable ^^
Jean Henri Chandler
Posted: Thu 08 Jan, 2015 3:12 pm Post subject: |
This was IGX, they had several swords plus a few people had brought their own. I don't think I cut with a Crecy because most of the ones I handled were fairly large. I know there was one Brescia Spadona the first year I think I cut with that, but I believe I cut with two other swords during the tournament, I remember I wanted to try different blades. I think that was in 2012.
Mark T: Thanks! I never left here I'm just mostly a lurker these days.
J
Matthew P. Adams
Posted: Fri 09 Jan, 2015 1:56 pm Post subject: |
Found this on YouTube
http://www.youtube.com/watch?v=ATtDymVb0P4
Someone cutting a milk jug with his Agincourt.
Hector, I think you've just answered a question of mine about the Albion Mercenary family of XVa's, they do swell distally to reinforce the point? Thank you!
Oh, and I'm with you on the blade honing, a well polished sharp edge is vital to a clean cut, especially considering linen and wool fabric. A sharp edge does not in any way need to be acutely angled. I've got an axe that will shave arm hair, and it both chops longer and is easier to maintain.
