Timo Nieminen
Posted: Wed 31 Dec, 2014 10:32 pm Post subject: |
Thanks for that! Good to see the distribution. Only leaves the question of whether Medieval bows were the same (which is a common Mary Rose bow question).
Definitely you don't want sharp edges/corners anywhere, when you're approaching the limits of strain the wood will cope with. "D with sharp corners" would be bad.
Will S
Posted: Thu 01 Jan, 2015 1:11 am Post subject: |
No worries. Happy New year by the way!
It's a tricky one regarding the MR bows being the same or different to medieval bows, because there's good arguments for both sides. On one hand they were the cream of Henry VIIIs crop, so you'd imagine they were as good and as powerful as you'd get.
On the other hand, it's a period where the Warbow was running out of use due to firearms, so perhaps they were either more powerful to attempt being used against better defensive methods, or less powerful than medieval bows as they didn't need to be clearing 240 odd yards with heavy plate-cutting arrows. The Tudor bodkin associated with the period certainly isn't a head designed for punching through armour.
Then again, when you look at bows like the Balinderry Bow from the 10th century, it was almost identical in dimensions and materials as these late Mary Rose bows, so you'd have to imagine the same size and weight bows being used from the 10thC to the 16thC at the very least.
If Otzis bow was finished, again it was almost identical.
Personally I'm of the opinion that the MR bows are pretty typical of medieval bows of the middle ages - they found a working method and made it a standardised procedure.
As a side note, while I know it's a popular theory, I'm not a huge fan of the idea that the D section came about due to maximising yield from a log. There's too much variation in a yew trunk for it to work. If it was ash for example, which grows straight and knot free then it would make sense (although a D section doesn't work at all with ash!) but yew always tends to have one side full of knots, or one side tension wood (ideal) and one side compression (not good for bows) due to the wood leaning as it grows. Those billets that Richard bought from Carson on PA aren't exactly split logs - those have been worked down with a bandsaw from the original split to get them as small as possible for easy international shipping (Richard is in the UK and Carson in America) and for ease of working. A split section of yew is always feathery and fibrous until it's worked down a bit.
I think the tree would be cut down, split to remove the sections that would make good bows and one bow laid out within that section.
You could possibly get a ring of D section longbows from one trunk if the bows were very narrow, the trunk completely flawless and the grain lying perfectly to split into ideal sections. With a typical MR style bow however, you're looking at having a stave around 2" wide to begin with, in order to lay out the 1.5" width of the bow. To get a ring of 2" wide perfect warbow staves seems impossible to me, but then I've only split and worked with less-than-ideal English yew which usually only yields two heavy bows from a large trunk section. Perhaps high quality Spanish, Portugese or Alpine Yew yields slightly more.
Benjamin H. Abbott
Posted: Thu 01 Jan, 2015 5:35 pm Post subject: |
Pieter B. wrote: | Add to this that there was no real incentive in western Europe to use a composite bow. They had composite crossbows so I assume they knew how to make one. It's just that the small form factor of a recurve composite bow didn't have any tangible benefits since horse archery wasn't a noble pursuit nor a way of fighting war. |
Current tests suggest that well-made composite bows are more efficient than yew longbows. This means arrows from a composite are faster, more powerful, or both. The preliminary numbers from big-eared Manchu bows indicates that infantry archers armed with such weapons might deliver 33-50+% more energy per arrow than infantry archers armed with longbows. Even heavy arrows from Turkish-style short composites deliver 11-17% more energy than heavy arrows from Mary Rose replicas. So some incentive potentially existed.
However, available records show that Turkish archers employed light arrows primarily or exclusively, so Europeans who encountered Turkish bows wouldn't have been impressed by their penetrative power. A 15th-century Burgundian who traveled to Turkey considered European bows and arrows more powerful, probably because of the difference in arrow weight.
Posted: Sun 11 Jan, 2015 9:08 pm Post subject: |
Rim Andries wrote: | Lafayette C Curtis wrote: | Would that justify composite recurve bows in the Netherlands in the 15th or 16th century? Probably not outside of hunting contexts, and not in the hands of anybody lower than the royalty and high nobility. If it's just recurves, though, we know that Burgundian Ordonnance archers were sometimes depicted with recurved longbows; the length and gentle recurvature of these bows, along with a two-tone colouring similar to the kind often used to indicate the English longbow's D-shaped cross-section, suggest that they might have been self or at most two-wood laminated bows instead of full-fledged composites. |
Thank you for keeping the dream alive |
Not really. If anything, the stuff I mentioned restricts how far you can stretch credibility by having a composite and/or recurved bow in the Low Countries. We have some pieces of evidence that indicate recurved self-bows were present and reasonably common among archers in Burgundian employ, but on the other hand paintings of archers' and marksmen's guilds from Dutch cities in the 16th and 17th centuries almost exclusively show straight/simple self bows, occasionally with recurved tips that may be interpreted as an actual recurve or as horn nocks on straight-limbed bows. Take this Van Helst, for example:
http://en.wikipedia.org/wiki/File:Bartholomeu...terdam.jpg
So, personally, I'd rather stick to self bows with horn nocks (and perhaps colourful grip wrappings) just to be on the safe side. Forget composite recurved bows unless you're specifically trying to portray a noble on a hunting trip.
