Forum Index > Makers and Manufacturers Talk > A simple rapier.... Reply to topic
Jesse Belsky
PostPosted: Sun 25 May, 2014 7:06 pm    Post subject: A simple rapier....         Reply with quote
Here's a rapier I just finished...pretty simple in its details, nothing too fancy. The hilt is steel, all welded construction except for the counterguard which is inset and brazed. Its mounted with a 35" Hanwei Practice rapier blade with a fullered ricasso. The pommel is secured with a 6mm recessed allen nut and the grip is spiral carved hardwood. If you're of the stage combat persuasion and like a lighter blade, I also have a 35" diamond schlager blade that can be mounted instead.
This is available if you're interested... www.jessebelsky.com/stageswords
 Attachment: 119.94 KB
 Attachment: 121.23 KB
 Attachment: 129.53 KB
 Attachment: 100.66 KB
 Attachment: 124.51 KB
 Attachment: 113.72 KB
 Attachment: 121.65 KB
 Attachment: 110.07 KB
Shahril Dzulkifli
PostPosted: Tue 27 May, 2014 5:04 am    Post subject: A simple rapier....         Reply with quote
Not bad at all!
- Marcus Aurelius
