seax in the rain
It was starting to rain, but I managed to photograph these before they go to their new homes...
From the top, first up is a 'mini-seax' in shear steel and horn with a 3 1/2" blade, about 7 3/8" overall.
In the middle is one of my experiments in wolf's teeth from last fall, made of wrought iron, 1095 edge, and bog oak for the handle, with a 6 1/2" blade, about 12 1/2" overall.
Last up is a patternwelded blade (wrought iron, 1084/15n20 twist, w2 edge) with a walnut burl handle. Blade is about 7 5/8" long, just under 14 inches overall. This one has a bit of an auto-hamon.
Here they are in their sheaths:
Very nice, I hope they found good homes! The rain makes a nice light for the picture.
What is "the experiment in wolf's teeth?" A pattern you found through the wrought iron? Bog oak is nice for the handle. Wicked point also.
Scabbards are all very nice also. Hard to say which seax I would like the best.
These all look very good. They have a very period authentic feel. I think the light really helped create the look!
Very nice and nice avoiding the rust from rain drops. :D :cool:
I like having seax in the rain. As Martha Stewart would say..."It's a good thing!"..... :lol: .....Beautiful work!......McM
Seax
Very nice work again George. I especially like the longer one, and the quality of the sheaths you create.
Robert
I had an order last year for a seax with a 'serrated' weld, what is also called a wolf's tooth pattern. I made a few experimental pieces to learn the technique, this was one of them. These images may help...
This was the initial pieces, one wrought iron, one 1095, with the teeth chiseled in. Unfortunately keeping the teeth aligned proved to be a problem. I took the wrought iron piece and another piece of 1095, and cut the teeth into the 1095 using the wrought iron piece as a pattern. These pieces were cleaned and fire-welded together, resulting in this...
The pattern stretched more than I wanted, but it worked. Since I had the 1095 piece with the teeth chiseled in, I tried fire-welding that bar to another piece of wrought iron, hoping that the force needed to fire-weld them together would also force the wrought iron down into the teeth of the harder 1095. That experiment worked better than I expected, and became the blade you see above. Here are the blades from that set of experiments...
By the way, this is the finished wolf's tooth blade that I was commissioned to make... I love it when I am challenged to try something I've never done, at least I am when it works...:)
Thank you for the explanation! If you had talked about it before I missed it. I saw some of your work before on SFI so it is nice to locate you here also. You are definitely on my list! The wolf's teeth is a really interesting pattern and it certainly was successful. Nice to see the in-progress photos. I like the bog oak handle a lot as well as I said above, and the sheaths too.
