J Helmes
Posted: Tue 20 May, 2014 5:20 am Post subject: Available: Pattern Welded Spear Head |
Hello,
Forge welded construction, brazed wings. Wings and socked of wrought iron, 1000+ layer edge, core of antique steel, iron and high carbon steel. The core is4 bar so the pattern runs in the same direction on both sides of the spear head. OAL 37 cm
Jeff
J Helmes
Posted: Tue 20 May, 2014 9:25 am Post subject: |
Sold . Thank you kindly folks!
Carl W.
Posted: Wed 21 May, 2014 5:21 am Post subject: |
Wonderful work. Thank you for making & sharing it.
G Ezell
Posted: Thu 22 May, 2014 12:27 am Post subject: |
That is some extraordinarily beautiful steel, it really does capture the look of pre-industrial bloom. Well done man!
" I have found that it is very often the case that if you state some absolute rule of history, there will be an example, however extremely unusual, to break it."
Gabriel Lebec
https://www.facebook.com/relicforge
