Posts: 1,241 Location: NC
Thu 27 Mar, 2014 3:22 am
Since I do not know your actual location, it is difficult to recommend a supplier in your area - if there even is one. Your best bet for parts is probably The Rifle Shoppe in Jones, Oklahoma, US.
www.therifleshoppe.com. They do offer some early matchlock parts but no wood stocks. That will be up to you or a local craftsman. But, be warned that the good folks at The Rifle Shoppe can be very slow in supplying the parts. They apparently cast the part as it is needed instead of keeping a stock on hand. I have heard stories of customers waiting months or even years for items. Also, the parts are rough cast and will need finishing and hardening where appropriate. If you have some experience in that sort of work then it should not be a problem for you but if not you will need to find someone who can do the work for you.
Dixie Gun Works, while it supplies a lot of antique and reproduction gun parts, is not likely to have much of what you need.
Good luck and let us see the finished product.
