Forum Index > Makers and Manufacturers Talk > German Type XVa c. 1400 Reply to topic
This is a standard topic Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Boris Bedrosov
PostPosted: Mon 09 Sep, 2013 4:54 am    Post subject:         Reply with quote
Yesterday was very fruitful.
Apart some good work on the khanjar from the "Yushman Project" (this will be shown very soon in the appropriate thread), I fitted the guard and the pommel of the sword.
There are some extremely minor fittings left, but as a whole - this is it.
As I gradually come to the end, I like this sword more and more - both as an object of art and purely as an instrument of war.
I hope you like it too.
Tokugawa Ieyasu
Find my works on Facebook:
Boris Bedrosov's Armoury
Kai Lawson
PostPosted: Mon 09 Sep, 2013 7:04 am    Post subject:         Reply with quote
This sword is going to look REALLY GOOD
It already does, and it's not even finished! Really impressed with the great pommel. The curves and ridges aren't easy to do, but they really make a difference on the finished piece
"And they crossed swords."
Radovan Geist
Likes: 5 pages
PostPosted: Mon 09 Sep, 2013 7:43 am    Post subject:         Reply with quote
I really like it! especially as it has you´ve used of my favourite pommel designs. One technical question: what was used to make those diagonal ridges? A small Dremel tool?
Boris Bedrosov
PostPosted: Mon 09 Sep, 2013 12:28 pm    Post subject:         Reply with quote
I used my Dremel tool with the flexible shaft, 1/2" sanding drum and 1/2" 120-grit sanding band.
It's good to know that you must work with new sanding bands, as the work is done mostly with the edge (not the surface) of the band, so the edge relatively quickly becomes useless.
After the work with the Dremel tool was done, I re-worked the ridges with a square file
Tokugawa Ieyasu
Mark Griffin
PostPosted: Tue 10 Sep, 2013 6:52 am    Post subject:         Reply with quote
This is really coming on beautifully, thanks for documenting it. Its like a 'miracle of birth' thing on National Geographic!
Boris Bedrosov
PostPosted: Sun 22 Sep, 2013 2:19 pm    Post subject:         Reply with quote
And finally, the guard and pommel were finished - sanded and polished.
I decided to blacken the guard and the pommel, thus taking the risk to be criticized far and wide for this inaccuracy - as you could see on the zornhau web-page, there aren't any traces of oxidation on the original sword.
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Mon 23 Sep, 2013 1:04 pm    Post subject:         Reply with quote
After the blackening
And some more pictures:
* the guard
** the pommel
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Fri 27 Sep, 2013 2:43 pm    Post subject:         Reply with quote
My first attempt to mount the guard on the sword was a failure, but after some minor re-matching, today everything went just perfect.
* the guard
Note that after hot mount, I used a chisel for additional anchoring of the guard.
** the pommel
Tomorrow is the day for riveting of the tang.
Tokugawa Ieyasu
PostPosted: Fri 27 Sep, 2013 5:13 pm    Post subject:         Reply with quote
Impressive work in every sense of the word, as I usually expect when seeing anything you work on. Big Grin Cool
Julien M
PostPosted: Fri 27 Sep, 2013 10:55 pm    Post subject:         Reply with quote
As always, excellent and extremely impressive work Boris (as Jean said, you've set your own standards to such levels that I'm not so surprised anymore either). This is the kind of things that motivates me to re start on old projects after along day at work, instead of wasting the evening in front of the television...so thanks for that!
Thanks for documenting your progress and looking forward to see this sword complete.
Daniel Wallace
PostPosted: Sat 28 Sep, 2013 8:42 am    Post subject:         Reply with quote
hey that's real chemical bluing not just paint on stuff isn't it Boris?
it looks great i just can't wait to see everything finished.
Boris Bedrosov
PostPosted: Sun 29 Sep, 2013 12:38 pm    Post subject:         Reply with quote
Absolutely no paint.
I heat the detail with a propane torch until it turns blue (that's about 250 degrees Celsius) , and after that I submerge it in a vessel full with fine machine oil.
I could do this several times - until I like the result.
Tokugawa Ieyasu
Boris Bedrosov
PostPosted: Sun 29 Sep, 2013 1:37 pm    Post subject:         Reply with quote
Me riveting the tang
and the result, after some filing, sanding and additional blackening
It's quite different from the original, but the decision was mine - you could feel free to cast stones on me, if you don't like it Big Grin Cool
Tokugawa Ieyasu
Dean F. Marino
PostPosted: Sun 29 Sep, 2013 1:43 pm    Post subject:         Reply with quote
Boris Bedrosov wrote:
So, I already have a guard and a pommel. What I need is a grip.
It was turned on lathe from beech.
Then the round form was cut alongside in two equal pieces, and both were made thinner - up to the dimensions mentioned in the data-sheet.
At the end both halves were rounded.
If I could ask a question... you had turned the grip on a lathe. Once turned (and no longer square), how did you do the cut? And did you encounter any saw kerf issues?
That truly IS a very stunning grip Happy.
Boris Bedrosov
PostPosted: Sun 29 Sep, 2013 2:21 pm    Post subject:         Reply with quote
Dean,
This cutting could be really pain in the a** Confused , but in any way is not easy.
It's quite hard to work with this round object. The lines for the cut are hard to be got straight, during the cutting itself the wood wants to roll almost constantly.
As I don't want to clamp it in the vice (or I'll get a lot of bits and dents from the jaws), I open the vice just a little bit - the grip goes between the jaws, but just partially and stays there relatively firmly. In this way I still have bits and dents, but acceptable, and mainly - I could get the grip in position I could work on it.
The cut is made not with ordinary carpenter's saw, but with some saw with tiny teeth - usually with hack-saw. I hold the saw in one hand (the right for me), with the other - the grip.
The saw kerf issues always exist, but I could minimize them if working carefully. If they get un-acceptable, it's easy to sand the scales a little bit. In any way, after gluing, cord and leather, nothing of the wood will be visible.
Tokugawa Ieyasu
Kai Lawson
PostPosted: Sun 29 Sep, 2013 2:26 pm    Post subject:         Reply with quote
Unlike Lando Calrissian (who's deal got worse all the time), I think this is looking better with every step towards completion
Boris Bedrosov
PostPosted: Sun 29 Sep, 2013 2:47 pm    Post subject:         Reply with quote
Well, originally this picture
should be a part from the previous post. But in any way, it's OK here too.
The scales of the grip were chiseled to fit the tang
Some posing for the camera
and the scales were glued with epoxy. After several hours I wrapped the whole grip with hemp cord, glued again with epoxy.
Tokugawa Ieyasu
Dean F. Marino
PostPosted: Sun 29 Sep, 2013 6:35 pm    Post subject:         Reply with quote
That is a truly STUNNING grip shape - all the more so because of the careful handwork involved. I'm really looking forward to the leather wrap Happy.
Lewis Ballard
PostPosted: Sun 29 Sep, 2013 7:10 pm    Post subject:         Reply with quote
Boris: Early on in this project, I think I said it was excellent. I WAS WRONG! It's beyond that. Your skill, your artistry, your vision awe me. You saw something in your mind and then made it, out of bar stock. Huzzah, sir. Huzzah!
Daniel Wallace
PostPosted: Mon 30 Sep, 2013 8:30 am    Post subject:         Reply with quote
looks really good Boris, i can see a little bit of the rainbow effect in the pieces - which lead me to think it was chemically done at first. this is going to be one heck of the fine looking sword when your done.
Page 2 of 7 Reply to topic
