I have an unfinished set of Albion Next Gen Knight parts for sale. I had purchased these while I still worked for Albion, and they came from lots of standard production parts.
The blade has been heat-treated, and ground to 3/4 of the way to completion. All the edge geometry has been fully established and the fuller has been ground and given the initial polish. The blade is currently in a 240 grit finish, but after sitting around in my shop/storage, it has a few minor rust spots that will come out with a little handwork.
The hilt castings are "as received" from the foundry. The sprues are still attached, and would need to be filed/ground down, and the surfaces polished to the desired level. The wooden grip core is fully shaped and ready to be popped apart and glued in place (after the pommel and guard are peened in place). The rivet block is one of Albion's standard machined pieces and are normally shaped after they are peened in place.
I can include some cord to do the under-risers with, and leather to do the wrap with if desired. I will also write up any instructions the purchaser needs.
Asking price is $400 plus $30 shipping CONUS
