Forum Index > Off-topic Talk > clicking noise Albion swords Reply to topic
This is a standard topic Go to page Previous  1, 2, 3
PostPosted: Fri 01 Jun, 2012 11:37 am    Post subject:         Reply with quote
Wouldn't the stabilized wood Albion uses on their grips make them less susceptible to humidity changes? Perhaps some folks who've worked with wooden grips can comment on how stabilized wood compares to natural wood in terms of humidity changes.
For the record, none of my 5 Albions click. Happy None of the others I've held or used (a couple dozen) clicked.
J. Hargis
Likes: 22 pages
PostPosted: Fri 01 Jun, 2012 12:06 pm    Post subject:         Reply with quote
Robin Smith wrote:
Justin King wrote:
Since Albion makes their swords to resemble period swords as much as possible, maybe the central question should be whether this was common with period swords? Not an easy question to answer, but maybe worth considering for those who collect "historically correct" swords.
I would bet it almost certainly did happen. Wood was vulnerable to humidity then as it is now, and our modern glues/epoxies are vastly superior.
Period swords rarely were the perfect specimens that you see come out of New Glarus. Assemmetries galore, crooked crosses, uneven fullers, etc...
That then raises the question of just how historically accurate are Albion swords, with perfect fullers, guards, precise pommels, etc.
For me, this is one reason I prefer Arms & Armor. While their work is outstanding, you will see many asymmetric elements in their swords and daggers. Much more historical, IMO.
Jon
Matthew P. Adams
Likes: 8 pages
PostPosted: Fri 01 Jun, 2012 12:23 pm    Post subject:         Reply with quote
I can't seem to find it but Peter Johnsson wrote somewhere in here that he would like to include some more asymmetries in Albions lineup but that the market demands closer to perfect recreations.
I'm a little on the fence on this, I think that if a smith in period had access to a CnC machine, and could crank out swords to within millimeters of the idea in his head, that he absolutely would. I guess it depends on whether you see swords more as an example of an historic artifact, or a tool.
Not that either is better, it just comes back to what you like. Happy
Robin Smith
Reading list: 17 books
PostPosted: Fri 01 Jun, 2012 1:53 pm    Post subject:         Reply with quote
Stabilized wood is LESS susceptible, but not insusceptible. Any wood is going to be effected by humidity. Stabilizing reduces the amount, but there is still shrinkage and swelling.
BTW, I haven't worked wood for hilts. But I have worked with alot of woods (cabinet shop) and I'm a fairly decent carpenter.
Jon
A historical sword would be made of piled construction of bloomery steel or a single bar of bloomery steel (very low C basically mild steel or iron) and case carburised*. This brings the outer skin up to higher carbon levels, but its not very similar to our modern steels. Plus no cast steel parts. No CNC blanks... Etc...
Albion and A&A make good swords. Both have areas where for reasons of cost or ease of manufacture or other reasons, they have to depart from historical examples. Even on Albions museum line swords you're not seeing real historical metallurgy.
Only way you are going to get a truly historical sword is to buy an antique, followed second by buying from a custom smith. That is not to knock either Albion or A&A. Kings and Princes would have killed for a sword of the quality that Albion or A&A can churn out as every day work.
Edited out unnecessary
J. Hargis
Likes: 22 pages
PostPosted: Fri 01 Jun, 2012 5:32 pm    Post subject:         Reply with quote
Robin Smith:
Some very valid points Robin, thanks.
However, with all the modern techniques employed there should be even more reason to expect such an expensive sword to be noise free. Obviously it doesn't bother some at this forum, which is fine, but I would find it annoying and disappointing.
Jon
Robin Smith
PostPosted: Fri 01 Jun, 2012 6:07 pm    Post subject:         Reply with quote
Jon
No doubt, which is certainly why (as has already been pointed out) Albion put this on their website:
"Great care was taken in the making and assembly of your Albion sword. However, even with the pains taken to seal and stabilize all of the organic materials used, extremes in temperature and humidity can sometimes create small expansions and shrinkage that lead to potential loosening of the hilt. Although rare, should this occur we offer refurbishment and repair by our shop at no cost to you apart from return shipping. All Albion Mark swords are guaranteed for life against defects in materials and workmanship."
The only way you are going to avoid such issues is just totally departing from historical construction methods and going with plastic grip cores or something.
Brandt Giese
Likes: 3 pages
PostPosted: Fri 01 Jun, 2012 10:16 pm    Post subject:         Reply with quote
Robin Smith wrote,
I feel as though we are beating a dead horse but please read the warranty. 1) I do not live in an area with extreme temps. 2) we have a good geographic sampling of responses with the issue even from the climate where the swords were manufactured. 3) there are no loose hilts. 4) Many swords with the noise have been fixed.
I would like to point out once again that this issue according to Mike at Albion is not a humidity expansion issue but an epoxy issue. He also stated something to the effect that it in no way hinders the integrity of the sword and is simply a noise which Albion will gladly repair if sent in.
Two of my swords have this issue and click through all 4 seasons. This is not a major issue for me as I will continue to buy Albions and I most certainly am not scared the world is going to stop spinning on its axis. The original post was a question concerning this issue and if potentially it led to greater issues which clearly it has not. I do not in anyway bash Albion as I have nothing but good things to say about them. The responses received on the issue back up Mike's response to me and confirms the integrity of Albion and their swords. I am still left with a couple thoughts to which I will leave for Albion as I do not want them or myself misconstrued.
Thanks Brandt
Stratos Diakoniarakis
PostPosted: Wed 25 Sep, 2019 12:28 pm    Post subject:         Reply with quote
Anyone know if you buy an Albion second-hand, if the warranty still applies for fixes? Or does it only apply if you buy it from them directly? Thanks.
PostPosted: Wed 03 Aug, 2022 7:40 pm    Post subject:         Reply with quote
Anyone know?
PostPosted: Thu 04 Aug, 2022 1:56 am    Post subject:         Reply with quote
Anyone know?
Albion certainly would know. I’d ask them directly. Happy
Page 3 of 3 Reply to topic
Go to page Previous  1, 2, 3 All times are GMT - 8 Hours
