Butt Cap for A&A Friedrich IV Spear / Longsword sword be
Hey everyone,
I have a couple of questions I am hoping to get advice on,
I have an A&A Friedrich IV Spear that I enjoy greatly; however, this spear does not ship with a butt cap. Has anyone else fitted this spear with one, or have suggestions for one which might work well? I have looked at the Windlass ones, but I do not know their diameter. My goal is to protect the shaft from damage while resting it on the ground.
Also, I have a A&A Dürer Bastard Sword (and scabbard) on the way, and I am looking for a sword belt to use with it. I have been looking at the Swordbelt for Long Sword (XVth Century Swordbelt) made by The Inner Bailey. Does anyone have first hand impressions of this product or speculation as to its functionality or historical accuracy? (I would get it with brass rather than nickel.)
Any ideas or feed back is welcome :cool:
Thank you much.
Re: Butt Cap for A&A Friedrich IV Spear / Longsword swor
There is no historical basis for that sword belt.
Thanks Nathan. Do you have any vendor/model suggestions?
I thought maybe I was on to something since this product was very reasonably priced and seems to resemble the sword belt in Durer's Knight, Death and the Devil. The only difference I can see is the lowest strap Y's out into two strap's on the belt made by the Inner Bailey and does not in Durer's engraving. That being said the front attachment area is somewhat obscured in Knight, Death and the Devil.
I'm sure this is a very commonly needed product- Feel free to let me know what you guys are using. Thanks!
Kult Of Athena lists some dimensions for butt caps. They do vary and usually have some taper. I cheated on my hAnwei spontoon and just bought a tapered bo staff.
http://www.kultofathena.com/spears.asp
Alternately and if you are handy with a file, you could work a plumbing pipe fitting end cap (they come in several diameters)
I was looking at that spear seriously this summer but came to a dead end on my budget. Especially for modern stuff but that spear is one I want.. Another alternative is simply a cord/leather lace/sinew to keep the end from splitting.
There have got to be some other images you can work from and ask someone doing leather work. Even call A&A for their suggestion for their sword?
GC
Glen A Cleeton wrote:
Kult Of Athena lists some dimensions for butt caps. They do vary and usually have some taper...
Thanks for pointing this out, the other sites I had looked at these same products on did not have the socket dimensions listed.
I've bought and used the Windlass butt caps without any problems but one does have to file down the butt to taper it to the inside diameter of the butt caps.
This one: http://www.kultofathena.com/product.asp?item=...r+Butt+Cap
A just bought a few that I haven't fitted to anything yet so it's easier to take a direct measurement of the inside and outside diameters of the socket at it's mouth.
I.D. : 1 3/32 "
O.D. : 1 3/16 "
Wall thickness: Approximately a hair under 1 /16 "
Weight: 9 oz. on my food scale.
Strong and stout construction carbon steel, the end is very solid and not hollow to the end ( not stainless )
Outside total length: 5 3/4 "
Inside length for socket: 3 3/8 "
Oh, I have use copper plumbing end caps: They will protect the end of your haft and not change the weight or balance of the spear. The Windlass butt caps will bring the COG back towards the butt by a few inches, and balance the spear head for a more centre neutral feel, they also give you a very strong butt end to hit with. ;)
Hope this helps. :D :cool:
I use these for spear butts but also for the ends of walking stick I make for myself and I really like them best.
This one also worked well as I used the buttcap for a spear and kept the lance head for a future project:
http://www.kultofathena.com/product.asp?item=...Lance+Head
The Greek Spear buttcap is very very heavy and the pointy bit is solid steel but not the right historical period style I think for your spear:
http://www.kultofathena.com/product.asp?item=...ar+Buttcap
The rounded buttcap I don't like as much as the first type but it't about the same in weight and dimensions:
Thank you for all the info Jean. That helps a lot. :)
