Go to page 1, 2  Next
Long handled swords with brazil nut pommels
I'm looking for pictures of swords with brazil nuts and grips longer than normal singlehanders, but they don't have to have full two handed grips. It's for one of my new custom projects. Similar to this sword from the Geibig article: http://www.myArmoury.com/view.html?features/pic_geibig21.jpg or this fantasy one (from a Game of Thrones, but looks quite historical), sword of Rob Stark (I couldn't find a better picture):
 Attachment: 56.82 KB
Don't forget the one in the "multiple miscellaneous" section of Records. I belive it's #8 in that section although I don't have the book handy.
There are a few threads showing such swords. Look for the "Early Great Sword" thread and "custom type N". I used to have all the relevant threads in my favorites because it can be hard to find the right thread here on myArmoury, but I erased them all.
Yes, good threads, I know about them, thanks anyway.
Tim, our member here, J.D. Crawford thinks that sword from Records might be the same as the one from the Geibig article, what do you think?
Triple fullered warsword with brazil nut pommel from this thread is also very interesting but the picture of it is not very good... http://www.myArmoury.com/talk/viewtopic.php?t...highlight=
Have you checked out Kazavecius's book on Lithuanian swords? It is available online and has a few examples of what you are looking for. Between the Kazavecius book, the myArmoury threads and the Geibig article, I think that pretty well covers every known example of the type. We'll have to dig up some new ones if we want more.
Could you find a link for me? Any google search including "Kazavecius" achieves no results...
Sorry, I misspelled it. Here is the address: www.club-kaup.narod.ru/kaup_r_kazakevicius00_orig.html
Thanks Scott, I've been looking for documentation on this area for some time and never saw this. -JD
Thanks Scott! Some very interesting stuff there...
These two might be pretty good examples of what I'm looking for, if proportions don't fool me, they do seem to have longer than normal grips:
I think the first is indeed a long gripped sword, but the second probably is not, just a rather narrow-bladed 1-hander. Type P's were never long gripped as far as I know, but these Lithuanian swords can always surprise you. Also, I suspect that some of the illustrations may be subtly distorted, and it seems that such distortions in illustration always lean towards making the grip look longer, never shorter.
Actually, I looked it up and that type P has a 12cm long grip.
Luka, I have just played with one of such longswords ... very beautiful to see, 12 cm handle, very long blade but, but, but, darnedly blade heavy.
Are you sure you would really want such a blade for your project?
This is a beautiful one that Michael Pikula made for Rex Metcalf...the pic (see download) and specs are provided by Rex Metcalf from another post here on myArmoury.You can find his post with more pics (w/scabbard) if you scroll half way down the attached page:
http://www.myArmoury.com/talk/viewtopic.php?t...ula+brazil
Bruno, am I to understand that you recently got to handle an original? If that is so, I am quite envious and would love to hear more about it.
Scott,
yes I'm in the habit of writing to museums hoping in generous answers .. often I get some very good ones.
This original has a 12 cm tang. I could handle it even for a small dry handling. Had it been a replica I would have judged it a poor sword ... aha, you never cease to be amazed by what is behind a glass case, neither you can say absolute truths
Edit: pics removed for copyright issues. Ples do not diffuse them if downloaded.
Blade is long (more than 85 cm) I suppose the original owner was a robust knight. Sorry i was in a hurry so i couldn't take serious specs. Blade at the debole still wants to cut, yes, i could notice it
Wow! Thank you very much Bruno. I am fascinated by ( even a little obsessed with ) these early greatswords. I really appreciate the pics and the measurements that you were able to provide. I really want to replicate one of these blade-heavy beasts, but I want to get it just right and not go too far nor fall short. If there are any other tidbits of information you can remember about this sword, I would really appreciate it. Things like approximate center of mass or even a more detailed comparison of how it felt in handling compared to other swords. Also, can you remember what the edge geometry was like? Did it have thin cutting edges or thicker axe-like edges? Is the entire tang length 12cm or is that the grip length? I find it interesting how students of the sword had to work so hard to disprove the myth of the crowbar sword only to find with further study that some swords are indeed quite crowbar-like. Variety is the spice of life! The blade I currently have has the following measurements- Blade length: 90cm, blade width at base: 5.45cm, blade width at 60cm: 4cm, blade thickness at base: 5.5mm, blade thickness at 60cm: 3.1mm. Fuller is 70 cm long and 10-16mm wide. Total tang size is 17 cm long by 2.1 cm wide. I think this blade is in the ballpark, but I want to make one with longer, wider tang, less profile taper and maybe thicker and/or with less distal taper. I am dying to get some detailed and accurate measurements of one of these swords so that I can proceed on something more than intuition and educated guesses. Thank you again Bruno, you have filled in another piece of the puzzle for me.
PS- what do you mean by "blade at debole still wants to cut, yes i notice it"?
Check out this thread for early great swords: http://www.myArmoury.com/talk/viewtopic.php?t=8309
Thanks Chad, I have seen it. Not much in the way of measurements. Marko Aleksic's paper on type N swords provides some good measurements, but not any info on total mass, blade thickness, distal taper, center of mass, pivot points, or any of those hard-to-find goodies that I so desperately want.
I have rather small hands, and still can't really imagine 12cm tang to be comfortable for any sort of two handed grip, especially with brazil nut pommel.
I can be very well missing something, and it's just a speculation obviously, but I would agree with suggestion about large guy wanting some "big guns", but still one handed ones. ;)
Page 1 of 2
