Forum Index > Historical Arms Talk > Mamluk armour versus Mongol arrows Reply to topic
This is a standard topic Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Timo Nieminen
PostPosted: Mon 27 Jun, 2011 3:39 am    Post subject:         Reply with quote
William P wrote:
because as the visby shows, lames can be of multiple different shapes,
but that shape of scale which seems to be in greek linothorax reinforcing, roman squamata (different armour types i know) as wel as mongol, inuit and byzantine lamellar , considering that that shape is so prevalent, i wonder why. is it maybe just that it looks like fish scales?
Rounded tops of lamellae reduce the chance of snagging clothing or your own weapon. Also reduce the chance for self-injury.
William P
PostPosted: Mon 27 Jun, 2011 4:19 am    Post subject:         Reply with quote
Dan Howard wrote:
William P wrote:
on the note of armour. how doesthat dendra armour handle in terms of comfort etc compared to an iron hauberk? or better yet, a medieval plate harness, if youve had the chance to try out the others of course.,
It puts a lot more weight on the shoulders than later harnesses. Some details here.
http://www.myArmoury.com/talk/viewtopic.php?t=8942
Best to comment on that thread rather than derail this one any further.
that was just an afterthought, has anyone actually done damage resistance tests on replicas of the dendra?
btw i also remembered, that peters visby i thought looked fairly different to the original, but according to THIS which is from the book 'armour of the battle of wisby' shows the reconstruction of this type of lamellar being worn
compare it to me wearing it. not as different as i thought, except his piece is using lames twice as wide as the original.
 Attachment: 141.23 KB
me wearing peters leather lamellar [ Download ]
 Attachment: 54.79 KB
reconstruction of the visby lamellar type 5 [ Download ]
Samuel Bena
PostPosted: Mon 27 Jun, 2011 4:39 am    Post subject:         Reply with quote
Dan Howard wrote:
No mention of armour at all, except for his helmet being knocked off his head. Dawson's account is a garbled version of two completely separate battles written by two different authors, one by Comnena and the other by Psellos. Yet another example of why most Osprey books are not worth the wasted space on the bookshelf.
The sources you pointed out make Dawson's work indeed dubious - interesting research and many thanks for correction !
View user's profile Send private message ICQ Number
Samuel Bena
PostPosted: Mon 27 Jun, 2011 5:10 am    Post subject:         Reply with quote
Dan Howard wrote:
The Sarmatians and Parthians and Persians didn't use stirrups and yet had no problems employing heavy cavalry with couched lances
Apologies for diluting the thread but Dan would you happen to have any evidence of the said ancient ("stirrup-less") nations employing their lances in the couched manner? I'm genuinely interested.
PostPosted: Mon 27 Jun, 2011 6:09 am    Post subject:         Reply with quote
P. H. Blythe, The Effectiveness of Greek Armour Against Arrows in the Persian War (490-479 B. C.), PhD, University of Reading (1977).
He doesn't specifically test a Dendra replica but he tested bronze plates that were the same thickness and alloy as Mycenaean plate armour against arrows and spears.
PostPosted: Mon 27 Jun, 2011 6:11 am    Post subject:         Reply with quote
There are a few discussions over on RAT
http://www.ancient-warfare.org/rat/index.html?func=listcat
William P
PostPosted: Mon 27 Jun, 2011 8:01 am    Post subject:         Reply with quote
and, generally speaking what was the result of those tests
btw, where can one usually find these articles online?
Ahmad Tabari
PostPosted: Mon 27 Jun, 2011 8:57 am    Post subject: Qarqal padding         Reply with quote
Since padding was being discussed earlier I might as well link this back to the Mamluks. I was reading an article called 'Know your weaons, know your enemy: a Mamluk training manual" by David Nicolle. Its basically a translation of some sections of a Mamluk furusiyya manual. One passage that was discussing the use of qarqals(padded garment) surprised me.
Question What possesses even greater protective qualities than the jawshan?
Answer A padded garment can be worn beneath the jawshan, as the Europeans wear beneath their iron cuirasses. This is the qarqal. It will protect the wearer from both heat and cold, and from the blows of maces and kafir kubat which soften the flesh and weaken the bones. If a mail hauberk is worn beneath it, then both protection and safety are found.
Although the manual states that the jawshan should be worn above the qarqal, it also reccomends that the mail be worn beneath the padding rather than above it. Any ideas why that would have been recommended? Also does the fact that the author of the manual identified the qarqal by referring to the Europeans "as the Europeans wear beneath their iron cuirasses" imply that such padded garments werent very popular among Muslim armies?
P.S. The Jawshan referred to in the passage is a lamellar cuirass.
PostPosted: Mon 27 Jun, 2011 3:09 pm    Post subject: Re: Qarqal padding         Reply with quote
Jawshan is interpreted by Nicolle as a lamellar but there are plenty of texts that use the same word to describe "mail and plates" armours. I think the same term was used for both and it depends on the time period which one is being referred to. What is the date for Nicolle's passage?
PostPosted: Mon 27 Jun, 2011 3:13 pm    Post subject:         Reply with quote
"A Greek hoplite could quite happily rely upon his bronze helmet to keep out both Persian and Scythian arrows, and on his breastplate and greaves, if he wore them. On the other hand, his armour was far from complete, and the eyes, right arm, and the neck were particularly vulnerable. His shield would provide adequate protection against arrows from the Scythian bow…, but not, at short range, against those from the Persian infantry bow." pp 195-6.
You could try looking here for an online version
http://ethos.bl.uk/Home.do
PostPosted: Mon 27 Jun, 2011 3:24 pm    Post subject:         Reply with quote
This might help too
http://comitatus.net/cavalryrecreate.html
Ahmad Tabari
PostPosted: Mon 27 Jun, 2011 3:41 pm    Post subject: Re: Qarqal padding         Reply with quote
The manual itself was not written by one author but seems to have been compiled over more than 200 years. I am quite sure the Jawshan referred to in the manual is lamellar as there is mention of silk cords in the Jawshan. Here is the link for the article http://www.ospreypublishing.com/articles/medi...ng_manual/
PostPosted: Mon 27 Jun, 2011 3:57 pm    Post subject:         Reply with quote
Excellent. A good read. Does anyone have access to the original text to confirm the translation?
It confirms the use of lamellar over mail by the Mamluks
"A padded garment can be worn beneath the jawshan, as the Europeans wear beneath their iron cuirasses. This is the qarqal. It will protect the wearer from both heat and cold, and from the blows of maces and kafir kubat which soften the flesh and weaken the bones. If a mail hauberk is worn beneath it, then both protection and safety are found."
and adds further confirmation to Kozan's complaints about lamellar:
"Every day he must train himself to dismount elegantly so that he does not break or damage it, and he must keep practising and improving this skill. If, during the winter, the cuirass gets wet or damp from rain, he must examine its leather straps and its connections carefully and wipe off any dampness or mud from its individual pieces and any wetness from its cords. If he fails to do this, the inside of it will rot and it will become out of shape. Such rotting shows negligence and carelessness"
I think it does. It also implies that wearing mail underneath the jawshan wasn't common either. Based on the time period I think he is referring to the European combination of coat of plates and pourpoint.
Ahmad Tabari
PostPosted: Mon 27 Jun, 2011 6:29 pm    Post subject:         Reply with quote
I have been trying to find the original Arabic version but I havent had luck so far.
Lamellar certainly wasnt a convenient form of armour. It no doubt would have been very uncomfortable fighting in Lamellar when it is raining. This certainly explains why it never gained popularity in Europe.
Gary Teuscher
PostPosted: Tue 28 Jun, 2011 12:16 pm    Post subject:         Reply with quote
There are a few reasons where I can see why one would wear lammelar over mail. Obviously, the better protection is one of them. And yes, a 2nd layer of mail over the first would also provide protection, though I am not sure if lammelar over mail would be easier on the wearer than mail over mail.
I do agree that to provide the same protection level, lammelar would be heavier. Ran some numbers a while back ago figuring a 50% overlap, and what weight would be needed to provide similar protection as mail (using William's tests as a guide based on the resistance levels of various thickness of plate vs mail). iirc these correctly, to get similar protection the lammelar would be about 50% heavier. Lammelar might provide better protection though than a similar thickness of steel plate - it has a give to it that plate would not, though not as much give as mail
However, it should be cheaper (less labor intensive) than mail, and you can do more spot protection. A lammelar curiass is going to be lighter than a full mail hauberk.
Plus, a thinner lammelar plate could well have been used if over mail, much in the way that breastplates in the chain and plate period were thinnner than those when used in a suit of full plate.
As to the abilities of leather/cuir boilli/Leather Lammelar, I saw some testing on utube regarding this, and this actually appeared to be pretty well done. I'm not sure if it was schmid's mail or not, but it held up very well.
There was not any arrow testing, but testing vs swords predominantly and a two handed axe.
The results -
8 weight leather provide virtually no protection. Even 2 layers of such leather provided almost no protection, and you are talking now about 16 weight leather, which is very thick. Get much thicker and it becomes difficult to wear, as 16 weight is about moccasin bottom thickness.
Now, the treated leather (boiled) provided better protection - it was certainly not impervious to the attacks, but could absorb much of a sword cut, though it was not as good against thrusts, and an axe hacked it up pretty easily. But it still provided some decent protection.
Problems with the Boiled leather - It's stiff of course, so good for spot protection but not overall armour unless articualted like plate. Other problem - it should a lot of stress after defending from 1 or 2 attacks. Unless they had a much better way of treating this, even boiled leather spot protection would be almost disposable, a few good hits rendering it useless.
The one type of leather based armour that perform better was boiled leather lammelar. This resisted attacks very well, though not nearly as well as mail, though it turned aside anything but a very hard, direct trust, and even limited penetration with this. The give of the lammelar seemed to give it the ability to withstand attacks without being damaged much.
Thing here though - as Dan mentioned, Leather was not a cheap commodity. Throw in the labor to make lammelar, and you probably have something that would cost at least 50% or more as metal lammelar - at offer less prtection, and it would be far less durable, so it wold make a lot more sense to have steel lammelar if going that route.
The mail was pretty well impervious to the attacks, about the worst you would see would be a few deformed rings or possibly even a few cut rings, with virtually no penetration.
No metal lammelar was tested.
About the only use I could see for even the fairly efficient leather lammelar would be in a very hide rich but metal poor culture, possibly certain steppe nomads.
Ahmad Tabari
PostPosted: Tue 28 Jun, 2011 7:19 pm    Post subject:         Reply with quote
I would love to see that video. Can you post the link?
Gary Teuscher
PostPosted: Wed 29 Jun, 2011 8:55 am    Post subject:         Reply with quote
http://www.youtube.com/watch?v=8jpuSzgkZN4&feature=related
Above is the Link, Ahmad. It is a series of tests, but you can access all of them from there.
As I said, I'm not sure what quality mail was being used - but it's not that important. It does not show mail as vulnerable, it shows how superior it is to leather type armours.
I'd love to see some quilted material tested as well and compared to leather, though I don't think we truly know the exact construction of thes texxtile based forms of armour.
I've heard 16-24 layers of linen, that's about it Happy
Daniel Staberg
PostPosted: Wed 29 Jun, 2011 3:28 pm    Post subject:         Reply with quote
The problem with textile armours is that it is very hard to find the right kind of linen cloth. Modern cloths are often not woven as tightly as historical linen cloths and the thread is weaker due to the fibres being shortend so that machines intended for cotton can be used. I've seen some samples of handmade attempts to recreate historical linen cloths and the end result is rather diffrent the typical modern linen cloth. Strong threads and more of them in each square cm will produce a cloth which is more resistant to damage when layered.
Timo Nieminen
PostPosted: Wed 29 Jun, 2011 4:32 pm    Post subject:         Reply with quote
Traditional long-fibre linen works for bowstrings. Likewise, silk. Both are among the best for woven textile armour. Hemp was/is used for bowstrings too. Is it also long-fibre? It's been used in East Asian textile armour, and for textile components of armour in East Asia. Was it used in Europe?
Ahmad Tabari
PostPosted: Wed 29 Jun, 2011 7:34 pm    Post subject:         Reply with quote
I just watched the video and I must say the hardened leather was impressive. It would be interesting to see a test done on wax hardened leather. As for quilted material, I imagine it would provide decent protection against sword cuts and maybe even arrows. But it probably wouldnt fair so well against spear thrusts. So far I havent found any tests on youtube.
Timo, as far as I know silk was not commonly used in European armour but I would bet that some French Knights would have worn silk shirts beneath their aketons during the hundred years war as additional protection from the dreaded bodkin arrows.
Page 5 of 7 Reply to topic
