Which would be the “one” sword that you would take into battle? Assume that you may be up against a mix of adversaries with a mix of medieval weapons but with limited to light armor (assume very limited to no plate armor) |
The Crecy |
56% |
[ 37 ] |
The Baron |
12% |
[ 8 ] |
The Knight |
12% |
[ 8 ] |
The Oakeshott |
18% |
[ 12 ] |
Total Votes : 65 |
Michael Edelson
Posted: Thu 02 Jun, 2011 4:20 am Post subject: Re: Oakshott all the way |
Chad Arnow wrote: |
Now that we've established we're talking about the Type XVII (), I feel the need to point out a couple things. The Type XVII's lifespan was much shorter than that of the Type XV (and its subtype). If Type XVII were better suited to armoured combat, wouldn't it have seen a longer period of popular use than the circa 75 years it had? |
Who says suitability to armored combat, for what was essentially a sidearm, should have resulted in a long lifespan? Most of the XVII I've seen are thick, narrow and wouldn't have been much good at anything other than armored combat. Maybe that is exactly why they had a short lifespan.
Quote: | I get the points people are trying to make, but some of the generalizations about a given type and its effectiveness seem overly broad in my opinion. |
I agree, and this is, to me, part of the problem with Oakeshott's typology. Oakeshott didn't know very much about using swords. Therefore he categorized these things based on appearance. Similar looking profiles, cross sections, etc. I would have preferred a categorization based on function first, appearance second (e.g. a XVa that is narrow and thick and one that is wide and flat shold not be the same type). Don't get me wrong, I'm grateful that the typology exists and it is very useful, but it could be better.
www.newyorklongsword.com
Byakkokan Dojo
http://newyorkbattodo.com/
Posted: Thu 02 Jun, 2011 8:06 am Post subject: Re: Oakshott all the way |
Michael Edelson wrote: |
Armour lasted much longer than Type XVII swords did. If they were as optimized for armoured combat as people often claim, why did they fall out of use long before armour use did? At about the time cap a pie armour becomes somewhat fairly common, Type XVII swords fall out of use. Again, logic says that if they were so good at armoured combat, they would not have been so easily (or quickly) replaced.
Of course there were always unarmoured troops on the field so some cutting ability is required. I own a Type XVII and it is a serviceable enough cutter. It's not the best I own, but it would still take a limb off. I know others would be better or worse cutters depending on their configuration so mileage will vary.
I think a better case about Type XVIIs could be made that they could have been too good at armoured combat: so specialized for that that they lacked versatility. But I tend to think a diamond section can be made at least as stiff as a Type XVII, while in some cases maintaining an edge profile that is still better for cutting. I feel Type XVIIs were an attempt at stiffness that didn't pan out as well as other attempts, so they were superseded.
Quote: | I agree, and this is, to me, part of the problem with Oakeshott's typology. Oakeshott didn't know very much about using swords. Therefore he categorized these things based on appearance. Similar looking profiles, cross sections, etc. I would have preferred a categorization based on function first, appearance second (e.g. a XVa that is narrow and thick and one that is wide and flat shold not be the same type). Don't get me wrong, I'm grateful that the typology exists and it is very useful, but it could be better. |
Oakeshott's system is by far the best one proposed so far for this era of swords. But I think he knew its limits too. I'd love to see a more modern system to see how it deals with certain things. The problem with what you're proposing is that it has the potential to be even more subjective and complex then Oakeshott's system. How thick and narrow does something have to be to move from one type to another?
I think the current system works precisely because it's general. It totally fits his intent to discuss a Type XV that is wide and flat vs. a Type XV that is thick and narrow. The typology is meant to be a common frame of reference for description. For most purposes it works. But not for all...
Michael Edelson
Posted: Thu 02 Jun, 2011 9:56 am Post subject: Re: Oakshott all the way |
Chad Arnow wrote: | Armour lasted much longer than Type XVII swords did. If they were as optimized for armoured combat as people often claim, why did they fall out of use long before armour use did? At about the time cap a pie armour becomes somewhat fairly common, Type XVII swords fall out of use. Again, logic says that if they were so good at armoured combat, they would not have been so easily (or quickly) replaced.
I think a better case about Type XVIIs could be made that they could have been too good at armoured combat: so specialized for that that they lacked versatility. But I tend to think a diamond section can be made at least as stiff as a Type XVII, while in some cases maintaining an edge profile that is still better for cutting. I feel Type XVIIs were an attempt at stiffness that didn't pan out as well as other attempts, so they were superseded. |
XVII are, in my experience, terrible cutters. Your Sempach (assuming your collection is up to date and that's what you're talking about) is the worst cutting sword I've ever used. Of the six or seven that I've handled, not a single one was actually sharpened (as though the folks at Albion said, 'Why bother?"). To cut with the one I had in my care I had to put an edge on it first, and even so a Talhoffer walked circles around it.
You say it would take a limb off? How do you know? Wrap a couple of layers of linen around a tatami mat and give it a shot. Actually, try just one layer.
The XVII I've seen in museums were all narrow, thick and crowbarish. I've seen XVa like this as well, but I've also seen some like the kind you described earlier...thin and wide enough to cut well.
So why did it go out of favor? I have no idea. We can make assumptions, and your assumption about it being overly specialized is a good one, but assuming that there would be an obvious rhyme or reason such as how long armor lasted is failiing to recognize dozens of other factors. Fashion, taste, etc. And a 75 year run is not exactly a failed experiment. That's several generations. Obviously it had its uses.
Can diamond cross section be made stiffer? Maybe. But that would for a sword maker to tell us. I assume that XVII are armor combat specialists because I've never seen one that wasn't a crowbar. Maybe there was a reason for that. I am not a sword maker and can only speculate.
Quote: | Oakeshott's system is by far the best one proposed so far for this era of swords.<snip> The typology is meant to be a common frame of reference for description. For most purposes it works. But not for all... |
I agree. That doesn't mean a better system can't be conceived, and if it were, it would have to come from martial artists/users, collector/curators and makers/designers working in harmony.
Byakkokan Dojo
Scott Woodruff
Posted: Thu 02 Jun, 2011 10:23 am Post subject: |
I agree with Chad. I think of the XVII as a transitional type, an early attempt at producing a stiff blade that was superseded when ways of making a blade that better combines stiffness with good edge geometry emerged.
As to the whole controversy about edge blows and armor, I think we tend to put too much emphasis on what the sword is doing to the armor as opposed to what it is doing to the man underneath. I think that a lot of the art and literary evidence that seems to show edge blows defeating armor are actually attempts at showing the blows defeating the man underneath. A killing or maiming blow that does little or no damage to the armor itself does not look very impressive, but that doesn't make it any less effective.
As to stiffness, I just can't seem to get enough. My Albion XVI is a fairly stiff blade, but with hard thrusts it does feel like a wet noodle in my hand. It is when it comes to cutting that I really appreciate its degree of stiffness. I agree that it is really only the last 5-7cm of the blade that matter when it comes to thrusting, after that the taper or breadth don't matter. If the center third of my XVI were a bit stiffer, maybe with a strong mid-rib, it would be perfect. But as it is, it is a very nice compromise, plenty stiff enough to cut with serious authority, barely stiff enough for reasonable thrusting and with a nice mass distribution that lets it handle like a dream.
One thing to keep in mind when it comes to stiffness is length. I find that a small change in length can have a drastic effect on stiffness. It seems that XVII's tend to be a few inches longer than most XVI's and XV's. Perhaps the XVII's design was a way of maintaining stiffness while adding that little bit of length. Perhaps it was considered worthwhile to sacrifice some versatility and cutting performance to get a little more range with the thrust.
Posted: Thu 02 Jun, 2011 10:44 am Post subject: Re: Oakshott all the way |
Michael Edelson wrote: | XVII are, in my experience, terrible cutters. Your Sempach (assuming your collection is up to date and that's what you're talking about) is the worst cutting sword I've ever used. Of the six or seven that I've handled, not a single one was actually sharpened (as though the folks at Albion said, 'Why bother?"). To cut with the one I had in my care I had to put an edge on it first, and even so a Talhoffer walked circles around it.
You say it would take a limb off? How do you know? Wrap a couple of layers of linen around a tatami mat and give it a shot. Actually, try just one layer. |
Yes, I have the Sempach, arguably the best Type XVII on the production market (and probably one of the only ones out there). Mine is sharp enough to cut pool noodles, which admittedly don't test much besides blade speed and edge alignment. It did cut that medium better than unsharpened MRL and Del Tin swords, so it has some kind of edge to it that makes it cut batter than unsharpened swords with thinner cross-sections.
It also cut into and most of the way through a big, thick-skinned pumpkin. The distance it made it into the pumpkin is farther than it would have to go through an arm certainly, No, I didn't wrap the pumpkin in linen. My point is that these swords can have edges that will do at least some damage. The unsharpened crowbar analogy is overly broad in my opinion. While they may never cut as well as some other swords, they can still cut enough to wound in certain situations.
Quote: |
So why did it go out of favor? I have no idea. We can make assumptions, and your assumption about it being overly specialized is a good one, but assuming that there would be an obvious rhyme or reason such as how long armor lasted is failiing to recognize dozens of other factors. Fashion, taste, etc. And a 75 year run is not exactly a failed experiment. That's several generations. Obviously it had its uses. |
It did have its uses, but given that other types had a longer lifespan that pre- and post-dated the XVII I think it's an easy case to make that those other types did the job better which is why they lasted longer. The 21st century armchair debates we have have the luxury of being done by those of us who don't face edged weapon battles with life and death on the line. I tend to believe our ancestors used what worked and things that worked well enjoyed wide use and a long life. Things that didn't had shorter lifespans (say 75 years instead of 200) and less widespread geographical distribution (Type XVIIs seem to have been found most often in Germanic lands and in England. Not many show up in France or Spain).
Maybe the English liked German fashions for those 75 years and that's why the Type wasn't more widespread. Maybe they were hard to make, or not versatile enough or died out for some other reason or set of reasons. All quite possible and likely factors in this. I still hold the opinion (which is all this is, just like yours is your opinion) that there must have been a practical limitation to the design that prevented a longer life. Since types like XVIII and XV had longer lifespans and more widespread distributions, especially during the armour age, I don't think it's a reach to say the XVII, with its shorter life and smaller distribution, must have been less effective.
We'll never know for sure, since we can't ask Friedrich von Tarant or Friedrich von Greiffenstein (two knights who died at the Battle of Sempach and had Type XVIIs buried with them) why they chose that style over other available options. We'll never know if they would have survived the battle with a sword of a different type. We also can't ask soldiers who didn't use this type why they chose something else. So we'll have to debate, guess, and surmise as well as we're able.
Michael Edelson
Posted: Thu 02 Jun, 2011 11:08 am Post subject: |
I think what we're both saying is that we don't know.
btw...fyi...pool noodles are a good test of your cutting ability as long as your sword is not too sharp (ability being a subjective word highly dependent on your goals, but I'm talking about just the ability to maintain good velocity and edge alignment here). If it is very sharp they offer no challenge. However, pool noodels do not test any aspect of the sword other than how sharp it is, within reason.
Pumpkins are worse than pool noodles because while they can be cut by dull swords they require little technique. You can flub your edge alignment consistency and still cut one. Even properly maintained edge alignment can result in a scooped shape to the cut because the pumkin's size and mass distorts the sword blade, which means you will learn little from cutting pumpkins except how much of a mess you can make. However, if the goal is to have fun cutting stuff, pumkins are great.
Byakkokan Dojo
Scott Woodruff
Posted: Thu 02 Jun, 2011 11:25 am Post subject: |
A XVII may not be much of a cutter, but I sure wouldn't want to be hit with one, armor or no. I get the impression that XVII's, while not cutters per se, were strikers. Thin, sharp edge geometries are of little use against a heavily armoured opponent, and putting aside the thrusting aspects, a XVII is exactly what I would want for making strikes and blows that would seriously mess up your game. The great degree of stiffness really helps here. Basically, I feel that a XVII is perfect for striking against armor, and as for the guy without armor, any kind of sword blade, regardless of sharpness or cutting ability, is going to take him down.
I do agree with Michael, most cutting mediums that people use (ie can afford) are pretty much useless for judging the cutting ability of swords. I plan on collecting some road-kill and covering them with linen and/or other armor in order to judge the relative cutting abilities of my swords. I am especially interested in how skulls and large bones hold up to sword-cuts (and vice versa.)
Vincent Le Chevalier
Posted: Thu 02 Jun, 2011 12:18 pm Post subject: Re: Oakshott all the way |
Chad Arnow wrote: | Quote: | I agree, and this is, to me, part of the problem with Oakeshott's typology. Oakeshott didn't know very much about using swords. Therefore he categorized these things based on appearance. Similar looking profiles, cross sections, etc. I would have preferred a categorization based on function first, appearance second (e.g. a XVa that is narrow and thick and one that is wide and flat shold not be the same type). Don't get me wrong, I'm grateful that the typology exists and it is very useful, but it could be better. |
I think the current system works precisely because it's general. It totally fits his intent to discuss a Type XV that is wide and flat vs. a Type XV that is thick and narrow. The typology is meant to be a common frame of reference for description. For most purposes it works. But not for all... |
I would say Oakeshott's typology is a good description of the various forms that have been used to achieve various blends of functional properties. In that sense it's telling about the how, but not really about the what (functional properties) and the why (what are they useful for in combat)...
I don't think the functional classification will be in the same discrete form as Oakeshott's, more likely a continuous description of some important physical properties that parallels the typology. It should be able to handle earlier and later swords as well, being unrelated to the technical details of how swords are made (i.e. what cross-section, profile etc.). There could be some coupling as a particular set of functional properties could possibly be achieved only by using the form of some Oakeshott's types...
Vincent
Ensis Sub Caelo
Christian Henry Tobler
Posted: Thu 02 Jun, 2011 7:30 pm Post subject: |
Fashion should never be excluded in any analysis of why a sword style did, or did not, remain in use.
But, even if we use efficacy against armour as our criteria, things get complicated. What kind of armour? There are significant differences in both handling and defensive qualities between different armours. Attacking someone in an abbreviated late 14th c. cuirass is different than facing someone in full c. 1450 Milanese kit. And, different gauntlet designs create subtley different grips on sword hilts - an hourglass gauntlet may work better with one design, while a long cuffed 'gothic' gauntlet might play better with another.
It's a complicated question, to be sure.
All the best,
Christian
Order of Selohaar
Michael Edelson
Posted: Fri 03 Jun, 2011 1:45 pm Post subject: |
In regards to effectiveness against mail, this is an example of what can happen against very small diameter mail (5-6mm) with an acute sword point (all rings are intact):
If a single ring is broken it goes in about twice that much. When you factor in flesh compression, it can go in quite deep. Not enough to kill, but enough to wound.
In testing penetration between various Albion swords, I did not find much difference among different sword profiles, the only real factor point acuteness. Of crouse this is far from a study with period swords, but then many suriviving examples don't even have their original points.
Also, a heavy crowbarish sword can break more links than a lighter sword with a more acute point, so that is something to consider as well.
Byakkokan Dojo
Sander Marechal
Posted: Fri 03 Jun, 2011 3:02 pm Post subject: |
Michael Edelson wrote: | In regards to effectiveness against mail, this is an example of what can happen against very small diameter mail (5-6mm) with an acute sword point (all rings are intact) |
Wow. Totally off-topic, that is some beautiful mail. Where did you get it?
The Knights Hospitaller: http://www.hospitaalridders.nl
Michael Edelson
Posted: Fri 03 Jun, 2011 9:37 pm Post subject: |
Sander Marechal wrote: |
Wow. Totally off-topic, that is some beautiful mail. Where did you get it? |
Juilo Junco Funes. He lives in Spain and does it as a hobby. Absolutely beautiful work. I only have small pieces of his mail, unfortunately. I can't afford him.
Byakkokan Dojo
