Darnley's Falchion
This one is new to me, and it gives me a good idea for reconfiguring the Cold Steel messer. :D
Looks like a horizontally recurved cross and either a globular or wheel pommel. Nice view of the scabbard chape!
 Attachment: 218.9 KB
cold steel messer
oooooo :D This'll be interesting how this will turn out :) What time of pommel do you plan to use?
I'll try the extra Alchem globular pommel I have lying around (I was wise to order two). I liked the way that turned out for the project shown below. I created a foot out of the body of the pommel. That type seems to have been common in this period and might provide just enough weight to counter the shortened CS blade. I have a cross that should work well for this, too.
The falchion shown in use by John Smith is very similar in form to Darnley's as well as some surviving 16th c. falchions. Note that his appears to have a globular pommel. This is probably the way I'll go, though it will be awhile before I get to it.
If anybody runs across similar artwork or surviving falchions please post them here!
 Attachment: 168.42 KB
 Attachment: 115.68 KB
I once saw a falchion in private hands (a Dealer) with a sheep's foot blade and the pommel was rectangular like an H1. The blade was very thick at the base and tapered continuously to the tip and was "flat ground". No scabbard. Would have looked a lot like this.
Do you recall what period it was from?
I have a feeling that in the first picture the pommel is a disc. There is a strip of slightly darker color that I interpret as a bevel of a type H disc pommel. Of course, it might be something else and the pommel is a sphere.
I think the first image shows a wheel pommel, too.
I think the Smith falchion can be interpreted the same way, as there appears to be a rounded shape just below his hand, as if it's the raised face of such a pommel. Hey, I can do that too! What I really need to do is round up images of a variety of falchions from this period so I can get a better sense of the stylistic boundaries. Both of the examples depicted here seem to correspond to the general form of the famous Medici falchion.
The dealer did not have any signs on the falchion, it had the same look as some of the big 14th cent swords that I can't point to right now since I'm at work.
The Danley looks like a type S pommel to me but it's hard to be sure.
OK, it reminded me of plate 16D in The Archaeology of Weapons. Must get a copy for my nephew, pity Dover only has the original text and not the updated notes from the Barnes and Noble edition in the 90's.
I feel safe saying the first one is a wheel and the 2nd is a ball or sphere. Look at the horizantal lines on the 2nd one. Makes it look like the artist was showing that it was round.
I don't feel the two falchions are similar at all. Not in blade, hilt or pommel. The smith sword even looks to have a double scooped false edge. The first one looks almost straight too as the 2nd has much more curve. I think the artist on the 1st one was trying to show a simple flaired hilt or a slight bowtie with a simple stepped wheel pommel maybe a type H.
That first pommel, looks like a wheel with a second bevel that may be giving the illusion of being globular.
