Posts: 249 Location: Whitewater, Wisconsin USA
Sat 19 Feb, 2011 2:50 pm
Nails for hafting a weapon head
I was wondering if this nail in the link would be period enough to use to haft a glaive or halberd head?
http://secure.tremontnail.com/cgi-bin/tremont...mp;mv_pc=9
Thanks in advance. :)
Attachment: 4.58 KB
Posts: 159 Location: Sartell Minnesota
Sat 19 Feb, 2011 3:27 pm
Seems to be on the thick side and may split the shaft easily.
I use just normal carpentry nails and cut them down a bit. And using a ball peen hammer you can peen over the head making it not look so modern.
Sun 20 Feb, 2011 12:11 am
That's very usefull thank you. :)
Posts: 56 Location: UK
Sun 20 Feb, 2011 4:37 am
I have got hold of hand forged rose head nails from this place and used them for pinning on a
shield boss and for holding on the hinges on a wooden chest very loosely based on the mastermyer tool chest.
www.suffolklatchcompany.co.uk
They look good, individual and forge black. I asked the head bloke politely and he mailed me a dozen or so. You might have to file the shank a little for your needs but might do the trick.
Posts: 8,310 Location: Montreal,Quebec,Canada
Sun 20 Feb, 2011 9:37 am
Good to drill a pilot hole for the nail to avoid stressing the wood and it's very difficult hammering in a nail without bending it when the haft is very hard wood inside a steel socket wall that won't give at all so that the wood grain has to be compressed and not just moved apart.
If the pilot hole is too big the nail will still be securely held by the wood. If the nail is a touch loose a drop of epoxy will hold the nail in and the nail will do it's main job of being an additional way to hold the polearm head in place in addition to a tight fit and the possible use of an adhesive ( Period or modern epoxy ...... should the head have to be taken off later heating to 250 degrees F. will make the epoxy let go and not be hot enough to damage the heat treat or burn the wood if the same haft is to be re-used ).
Posts: 41 Location: Germany
Sun 20 Feb, 2011 10:19 am
Just search ebay for forged nails or "geschmiedete Nägel" that's forged Nails in German. There are a lots of nails in German ebay but shipping might be a bit to expensive for your needs . Or just Try
http://www.rockler.com/product.cfm?page=1152
http://www.sevenpinesforge.com/nails.html
http://www.horton-brasses.com/store/nails/wroughthead
I hope this will help you!!!
Stephan
Sun 20 Feb, 2011 7:33 pm
Thank you for all the links! Some very promising nails there, and Jean thank you for mentioning the guide holes. :)
Posts: 643 Location: Minnesota, USA
Sun 20 Feb, 2011 7:56 pm
| Christopher Finneman wrote: |
I use just normal carpentry nails and cut them down a bit. And using a ball peen hammer you can peen over the head making it not look so modern. |
I've used the same method as Christopher with great sucess. For photographs, search for a thread titled "Hafting my Poleaxe Head". I would normally provide a link, but don't know how to use my cell phone well enough. :blush:
Good luck Robert!
Sun 20 Feb, 2011 8:36 pm
Thanks Scott, I might end up going with that method since it's cheaper and modern day nails are alot more common. :)
Posts: 162 Location: Peace River, Alberta
Sun 20 Feb, 2011 10:55 pm
Cut nails
Robert,
The cut nail that you posted a picture of is actually a superior product to a wire nail for what you are trying to do. The nail has to be driven in with the flats parallel to the grain, when done this way it acts like a chisel and cuts through the wood fibres and bends them down in the direction of the nail travel. This acts like a featherboard and actually grips the nail tightly. If you look at older construction, be it furniture, flooring, or whatever that is using cut nails you will see that they have been driven directly into the wood very close to the end grain without any pilot holes or splitting. If you check wood working stores like Lee Valley you will be able to find rose head cut nails in several sizes, I am sure that they would have one to fit your project.
Posts: 616 Location: Toronto, Canada
Mon 21 Feb, 2011 6:25 am
If you read Waldman's book on hafted weapons, you will learn that the period pieces examined were fastened with clinch nails. Those decorative cut nails at the start of the thread have too much body in the shaft. Using them like rivets will eventually split the wood under blows, even predrilled. If its a parade and display piece, who cares? It you plan to hit anything with it.... prepare a second shaft while you have the jigs set up.
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
