Detail photo -- Howard Clark forge folded blade
Just fwiw, a detail shot of a forge folded blade by Howard Clark fully polished. Definitely different than a nihonto, but it has its own unique look.
Howard Clark
Truly amazing work!
Ron
Just out of curiosity is this the Darryl Mier stock that Howard normally uses or the folded 1086 that he has done a few times?
Daryl Meier
Beautiful stuff! Good thing I don't have anything else to spend money on (who needs a savings anyway....).
Looks awfully rough to me. I bet a nice 100 grit emery cloth would take all of those nasty squiggles and ripples out :eek:
All kidding aside, neat stuff, just neat as all get out.
Yeah, that would work... ;) A nice angle grinder works well too...
Thanks, guys. I just polish 'em. Howard (and Daryl) makes 'em.
Re: Detail photo -- Howard Clark forge folded blade
As you mention, this is quite unique and perhaps defined by modern materials and techniques.. but I'm curious, with this particular example, is there any historic/ traditional terminology to define such patterns? Or must you combine multiple terms when attempting to describe it?
Some stuff, sure. It has a *very* tight itame hada. And I would also venture to say that it has a notare-eque hamon with some hataraki and pronounced ashi. But many of the activities Howard gets in some blades really don't have equivalents in the nihonto world and I hesitate to use the same words. If the blade was made from tamahagane, the composition would obviously be dramatically different. And with lower carbon levels. Japanese smiths usually use a heat treating method with temps, etc. that would probably result in instant fractures of the very high carbon levels guys like Howard uses. But his control over it, his ability to get incredibly tiny grain, and his ability to get it drawn back fast enough to prevent that failure results in a stiffer, harder, and more resilient blade in many respect. The edge holding of his blades is astounding. If he was using lower carbon steel we'd be seeing things like larger crystal, a thicker and more consistent habuchi most likely, and a variety of other things. Also the methodology of folding the steel in the manner that it is done also affects the appearance of hada. Once you know what you're looking at there's no mistaking one for the other.
So. With all that said. Apples and oranges. Some terms apply quite handily to Howard's work. Many other aspects defy traditional categories. As a result some don't like the work. That's fine. But you can't argue the performance either.
I'm finishing up the blade i had posted pics of in an earlier thread where it was in kaisei stone I believe. I'm finishing the burnish tomorrow and if I have time I"m taking some photos. San mai blade. Much more traditional looking. Very Howard as well. But more a traditional appearance. The blade pictured in this thread was pushing towards hitatsura as well with hardening pushing up into the shinogi-ji and mune (back of the blade essentially). Really Howard pushed the limits of the steel on that blade. Something he likes to do being a control freak and all. In a good way of course. ;)
Saw your pm here and noticed on my caller id that you called earlier, Nathan. Sorry, but I had the phone on the machine as I'm behind and have been trying to catch up when I can. So I was in the workshop with the ringer off, Pink Floyd on full crank, working my fingers off.
