Review enlargements - white boxes?
Lately I just get white boxes, sometimes a spiraling circle but then just white. Happens when signed in too. The enlargements used to work fine, after signing in.
If problem is at my end any hints appreciated. (Only thing I tried was turning off IE popup blocker feature.)
Sorry for trouble & thanks.
What browser are you using? IE? I've been using Google Chrome and am having the same problem and have just read that Google's newest update now has a compatibility issue. I may have to pick a different codebase to avoid browser upgrade bugs. :(
I changed to a different version of the "lightbox" image viewer. This avoids the newest round of browser updates that have introduced a backwards-compatible bug. Since this isn't a technical forum, I won't get into the details other than to say I've tracked down a bug, removed it, migrated to a different lightbox codebase, and updated 400+ files.
And just another example of the amount of work you put in to keep the site functional and keep us happy and fix annoying time wasting problem that must be very frustrating at time :!: Thanks for all that work. :) :cool:
deleting posts and stuff
And just another example of the amount of work you put in to keep the site functional and keep us happy and fix annoying time wasting problem that must be very frustrating at times :!: Thanks for all that work. :) :cool:
ironically my last post is giving you more work to do as I must have clicked on the QUOTE button when I meant to click on EDIT and ended up making a double post ........ really sorry about that. ( And delete this post also if and when you fix the problem unless it's not worth the trouble .......... :blush: :( :cry: ).
So why not click the Delete Button [ Linked Image ] and remove it?
You can delete your posts if it's the last in the topic (which it is not, now).
(Chalk this up to "Teaching a man to fish" rather than giving the fish... haha)
The delete button doesn't seem to be there for some reason on this Forum. ( If it is I didn't see it, neither did i see the edit button ? ).
EDITED: The EDIT button is now back, I understand about the DELETE button being for only one's last post but the EDIT button was also missing for some reason when I first wore the above.
I would normally have deleted the double post and edited the first post for a typo which was the original reason I was trying to do an edit.
This EDIT relates to Nathan's post below and for the obvious reason of not adding a new and redundant post I made this explanation as an edit and not as a new post.
You can only delete a post if it's the last in a topic. Allowing people to delete other posts would ruin the flow of a conversation and allow other malicious things to happen.
