Ben Potter
Posted: Tue 02 Nov, 2010 10:35 am Post subject: tying a turkshead in wire |
I was wondering if anyone knows the tricks to tying the turkshead on the wire wrapped grips?
Ben Potter Bladesmith
For any other man's,
Nor that I will be ashamed
Of my work torn hands-
Knowing it would be steep,
And the consequences reap.
Posted: Tue 02 Nov, 2010 10:50 am Post subject: |
I'd seen this series of photos before (scroll past the juvenile squirrel) but just now noticed that instead of following a single strand, Eljay starts with a bundle. This should make things MUCH easier because it's hard to get the individual strands "stacked" properly when following a single strand. Huzzah! Funny...I was sitting at lunch today fooling around with another USB Turk's Head and wondering how to make my wire work neater. The answer is in these photos! Couldn't see it until I'd done a couple the hard way. Now I can finish my Town Guard upgrade!
http://www.myArmoury.com/talk/viewtopic.php?t...ight=turks
PS: I should point out that each of the strands shown here is composed of two lighter strands twisted together. Here's the way I do that--Estimate the amount of wire I need, double it, add enough to guarantee a surplus, fold in half and tie one end to create a loop. Clamp a nail in a vise and put one end of the loop over that nail. Bend a small nail into a hook shape and secure in an electric drill. Put the hook through the free end of the loop, stretch the loop lightly taught and start slowly winding. Keep tension on the loop or it will buckle and twist out of control. Don't use too much tension, though, especially with wire this light. Use the same process for grip wire--to get a herringbone pattern, make two of these loops, turn one right, the other left and apply them to the grip back-to-back. The longer you wind the loop, the finer the pattern, but if you overdo it the loop will buckle.
R D Moore
Posted: Tue 02 Nov, 2010 1:06 pm Post subject: |
Be careful not get distracted by the other eye candy in Sean's thread! Homer Simpson's comment keep's popping into my mind: "It doesn't look easy, but I bet it is."
Posted: Tue 02 Nov, 2010 1:13 pm Post subject: |
R D Moore wrote: | Be careful not get distracted by the other eye candy in Sean's thread! Homer Simpson's comment keep's popping into my mind: "It doesn't look easy, but I bet it is." |
That's a personal favorite. Actually, the technique is incredibly simple if you see it done or manage to do it yourself. The great challenges of the TH, in my limited experience, are in the scale you have to work at, keeping the strands neatly stacked, securing the knot and getting a perfect fit on the grip. Again, Eljay's multi-strand technique should reduce most those problems.
Ben Potter
Posted: Wed 03 Nov, 2010 12:21 am Post subject: |
Wait so the TH is not tied in place?
That is relatively easy then. I thought you had to tighten it on the grip and couldn't figure out how to work the strands through with out kinking them.
Thanks
Stephen Wheatley
Posted: Wed 03 Nov, 2010 3:04 am Post subject: |
Again Sean, inspirational! I've got about twenty swords awaiting decent THs! I'll have yet another go now I've seen the tutorial photos. Thus far the techniques eluded me and I've been using bronze plumber's olives - not bad but not the same, especially not when you consider the bother I had finding useable rayskin!
Will post some pics if success.
Steve
Stephen Wheatley
E.B. Erickson
Posted: Wed 03 Nov, 2010 4:57 am Post subject: |
Sean,
True, I start with a bundle, but my bundle is composed of one long strand folded back upon itself 3X. So my Turk's heads are still of one strand of wire.
--ElJay
Posted: Wed 03 Nov, 2010 7:11 am Post subject: |
E.B. Erickson wrote: | Sean,
--ElJay |
The more I thought about those photos after posting the more I realized that they couldn't really be separate strands because that would leave two loose ends, complicating the finish even further. Couldn't account for only one "tail" tucked into the end of the grip. I wondered if they were folded and...sure enough! Many thanks for the clarification. It's all coming together now. Picked up some 28 ga. steel beading wire on the way home last night and can't wait to try this!
Christopher Treichel
Posted: Wed 03 Nov, 2010 8:55 am Post subject: |
Ok... so here is the jewlers trick to tying a great turkshead out of wire...
the problem is pulling the wire tight at each turn... and then still being able to get the wire through on the next turn...
Step 1: get really good at tying turks heads out of nylon string like thick fishing line (available where salt water fishing supplies are sold).
Step 2: get nylon string in the same gauge as your wire (if cheating and using double strand wire get a gauge that is about that thick or slightly thinner)
Step 3: tie the turks head in place with the nylon string
Step 4: follow the nylon through with the wire removing the nylon as you go... now you don't need to worry about tightening the wire as its already where it needs to be.
presto really well done turks head out of wire... there are all kinds of ways of cheating this method such as braiding the wire straight and then tying a one loop turkshead and soldering the ends but the method above is the easy way of getting it done...
