Problem with sword scabbard and how to fix it?
I recently purchased a Tinker Pearce Bastard sword and while I am very happy with the overall purchase and quality of the sword, there is a minor snag with the scabbard (literally) that bugs me.
Basically, as I slide the blade into the scabbard, once the tip reaches almost all the way down the scabbard, sometimes it snags on something inside the scabbard - basically gets stuck a bit. It only happens sometimes, usually when the tip of the blade is lies on one side of the scabbard. It feels as if there is something loose inside, maybe a piece of leather? And sometimes the tip catches this loose bit and snags.
I am a novice in the hobby, so I have no idea what it could be. I don't even know how a typical scabbard is constructed (by t he way, this one is made of wood). I tried flashing a light inside to peer what is going on, but no use. I would probably need an endoscope te get a good look inside :(
I have no idea how (if at all possible) to try to fix this....any ideas please?!
On a related note, I would welcome any advice on sword maintenance.
Thanx
On the H/T scabbards, there is a black plastic insert that holds the tip to keep it from rattling. Get a wire coathanger, straighten it out and put a little hook shape in the end. Try to reach down in there and just snag it out, it is only held in place by friction. Then, after you have gotten the plastic out - drop a couple small pieces of wool into the scabbard and push them down with your blade. Add just enough wool - one small piece at a time, until you solve any rattling. :)
I like this idea :)
It's that simple? :surprised:
I was worried that maybe it's a structural thing and that I'd have to ditch the entire scabbard or risk damaging the tip (it's extremly pointy by the way :D).
I'll try this and see if I can pry it out...
Thanx for the advice ;)
Yeah, that's it. You should be able to get it out easily. On one of my H/T scabbards, I did not even have to fish it out. I just turn it upside down and tapped it on my workbench and it fell out.
Good luck with getting it out of there! :)
Good tips, Jon. I know they weren't aimed at me, but thanks nonetheless- I have a H/T Bastard on the way and this will likely be a problem I encounter as well.
One thing worth mentioning in regard to the OP, however, is that H/T scabbards are NOT wood, but fiberglass. Oh, and just as a precautionary thing, please check the metal piece at the mouth of the scabbard to make sure that it does not touch the edges of the blade as you draw and sheathe the sword. I've seen a few people have issues with this, and it would be a shame for your sword to get dulled by accident like that.
Enjoy! That is a very awesome sword.
-Brogdon
