I have posted the original image along with the final product.
Broad blade double edged toward the rounded point, with the back edge drifting out towards a third of the way up the blade, and with a wide shallow fuller along the back edge of each side , hilt comprising of thick arched cross piece of oval section, inlaid with numerous flat silver roundels on each side, flat tapering tang and lobated pommel incised with pairs of lines and decorated en suite with the cross piece around the base.
78.5cm blade.
I have made a slight alteration to the dimensions, the scale from image to full size was to 4.8. The grip measured approximatly 3.5inches which wouldn't be comfortable for the customer to hold, after discussing this with the customer i added another inch to the grip. At this point i also discussed the grip and decided on the antler and steel rings.
The 'gypsy fittings' ( the holes bored into the pommel and crossguard) were originally silver fitted but after a conversation with the customer he decided upon sourcing his own gold and fitting them personally. Being why they are left unfinished.
The construction of everything was completely from scratch using the forge, the anvil, and a lot of careful grinding drilling and polishing.
thank you for your interest
Josef
White Well Arms
White Rose Armoury
www.whitewellarms.com
