Forum Index > Makers and Manufacturers Talk > Frankish Narrow sax and intro Reply to topic
Petr Florianek
PostPosted: Sat 09 Jan, 2010 1:52 pm    Post subject: Frankish Narrow sax and intro         Reply with quote
Hello! This is my first post, in this section, so I would like to Introduce myself. My name is (obviously) Petr Florianek and I live in Czech republic. I am part time maker specializing in Early Medieval/Dark ages stuff. I work with blades I made myself and also with blades of other maker, including Patrick Barta.
I do carving in wood, antler and bone, engraving, etching, leather work. I also started to forgeweld my own blades. I love to make cooperations with likeminded makers around the globe. I sometimes take commissions but mostly make what i want to do.
This first piece I want to present here is narrow sax. Its based on many examples found in France and Netherlands. Its based on finds from 6th century.
I forgewelded blade from wrought iron and something like O1 steel and forged the blade to shape. I filed and sanded blade and cut grooves and engraved snakes with chisel gravers. Fitings are wrought and are peened on the tang. Handle is ash covered with leather, glued with bone glue over 4 raisers for better grip.
Oal is 47 cm
Blade lenght is 33 cm
Let me know what you think and if you have questions
Petr
PS: I want to say thanks to Peter Johnsson and Jeroen Zuiderwiik for great help with resears on this one
 Attachment: 67.46 KB
Stephen Curtin
PostPosted: Sat 09 Jan, 2010 4:18 pm    Post subject:         Reply with quote
Hi Petr and welcome
Thats a good looking seax you got there. I especially like the engraved snakes, are they taken from a historical example or are they your own design, either way nice work Big Grin
Éirinn go Brách
R D Moore
PostPosted: Sat 09 Jan, 2010 6:20 pm    Post subject:         Reply with quote
Hi Petr
And allow me to welcome you to this forum as well. I've been following your projects on Don Fogg's forum and I'm very happy you have joined us. Please allow me to post a very small sample of work you have done that I've archived:
 Attachment: 74.38 KB
 Attachment: 89.27 KB
 Attachment: 75.85 KB
PostPosted: Sat 09 Jan, 2010 7:37 pm    Post subject:         Reply with quote
Petr: Welcome to the site and that is beautiful work. Big Grin
Petr Florianek
PostPosted: Sat 09 Jan, 2010 8:40 pm    Post subject:         Reply with quote
Stephen Curtin wrote:
....are they taken from a historical example or are they your own design....
part of both. bands of snakes and braids are often engraved on these weapons, but not this particular setup. I would call it "work in tradition" "or recreating a type"
To others: thanks for kind words and welcome.
Mr. Moore: heres a pic of finished pair of those you posted:
Tim Lison
(11 total ▮ 100% positive)
PostPosted: Sat 09 Jan, 2010 9:13 pm    Post subject:         Reply with quote
Looking good Petr! Keep them coming!
Tim Seaton
PostPosted: Sun 10 Jan, 2010 8:21 am    Post subject: vry kool         Reply with quote
well done sir Cool welcome to the fourm!!!!!!!!!!!!!
Jeremy V. Krause
PostPosted: Sun 10 Jan, 2010 9:44 am    Post subject:         Reply with quote
Welcome Peter!
Those look great. I especially like that you are using traditional blade construction.
Jeroen Zuiderwijk
PostPosted: Mon 11 Jan, 2010 2:49 am    Post subject:         Reply with quote
I'd like to especially add that this is one of the very rare sax reproductions that actually matches historical examples, including the engraving as is typical for narrow saxes. This is probably the most historically accurate narrow sax reproduction that is currently out there. And extra kudos for using wrought iron with a steel edge and not etching the wrought Happy
Jeroen Zuiderwijk
- Barbarian metalworking
- Museum photos
Petr Florianek
PostPosted: Mon 11 Jan, 2010 3:29 am    Post subject:         Reply with quote
Haha! Kudos for NOT making something :-)
The true is that as i welded the bilet much shorter tan actual blade and draw it by hand (i have more trust in my right hand than in welding on frozen anvil so i wanted to keep welding less then 20 cm). After drawing and filling and HT i gave the blade really quick etch to see where the weld line exactly runs. I was afraid that it could interfere with some scraping or engraving (not a case, it is far bellow. After that, sanded the etched layer out.
Jeroen Zuiderwijk
PostPosted: Mon 11 Jan, 2010 7:10 am    Post subject:         Reply with quote
Oh yes, I much appreciate extra efford put into historical accuracy, even if it's barely visible or even invisible in the end result. Most people would etch the wrought to show the pattern, even if it was no reason why the original would have been etched (except of course when there's patternwelding for visual purposes, and even then etching may not have been done in all cases).
Jeroen Zuiderwijk
- Museum photos
Paul Hansen
Likes: 5 pages
PostPosted: Tue 12 Jan, 2010 2:49 am    Post subject:         Reply with quote
Very nice work Petr! I'm looking forward to seeing more. Big Grin
Antonio Lamadrid
PostPosted: Tue 12 Jan, 2010 4:10 am    Post subject:         Reply with quote
I just checked Mr. Florianek’s web and I could not stop the drooling.
The amount of top bladesmiths and armourers that Czekia (and to a minor degree Poland) produces has always amazed me. We have nobody around here. How bad is envy!
Jeroen Zuiderwijk
PostPosted: Tue 12 Jan, 2010 5:13 am    Post subject:         Reply with quote
Well, the only way to do something about that is to become one Happy
Jeroen Zuiderwijk
- Museum photos
Petr Florianek
PostPosted: Wed 13 Jan, 2010 9:31 am    Post subject:         Reply with quote
I was cutler or hiltsmith before, i started forging because of long waiting lists at bladesmiths
David Etienne
Reading list: 8 books
PostPosted: Wed 13 Jan, 2010 10:29 am    Post subject:         Reply with quote
You did well, Petr, you have a gift. I really like your realisations and I'm eager to see the rest of your production.
David
P.S. I've just received my sword from Vladimir Cervenka. Are you all so talented in Czech Republic?
Petr Florianek
PostPosted: Wed 13 Jan, 2010 11:21 am    Post subject:         Reply with quote
well, hopefully no! :-) Thanks again, but i feel that i am on the beginning of my journey
Ben Potter
PostPosted: Wed 13 Jan, 2010 12:18 pm    Post subject:         Reply with quote
Vítejte na myArmoury Petr. Good to have you here.
(I hope that is right, language isn't my forte )
Ben Potter Bladesmith
For any other man's,
Nor that I will be ashamed
Of my work torn hands-
Knowing it would be steep,
And the consequences reap.
Dean Whitlock
PostPosted: Thu 14 Jan, 2010 7:15 am    Post subject: Bone carving techniques         Reply with quote
Hello Petr,
I am very impressed by your workmanship. I haven't tried metalwork but I have done a little bone carving and you are far, far better than I am! Do you have some advice or suggestions you could share with us about how to work with bone?
Thanks very much,
Dean
Petr Florianek
PostPosted: Thu 14 Jan, 2010 8:17 am    Post subject:         Reply with quote
Ben: good on you! almost without mistakes
Dean: ask me what you want to know, i will try to answer!
