Forum Index > Off-topic Talk > need viking shield info Reply to topic
Etienne Hamel
PostPosted: Sun 08 Nov, 2009 7:35 am    Post subject:         Reply with quote
white pine planks shouldn't be difficult... oh and for the linnen how much should i put? and should i display the linnen in a cross fibers pattern like this # (sorry for the english if you don't understand what i want to say is putting the first layer one way and the second one another way or if you prefer take a look at the number sign the horisontal lines are one and the vertical one is the other)
Viktor Abrahamson
PostPosted: Mon 09 Nov, 2009 1:59 am    Post subject:         Reply with quote
Make sure the first layer of cloth is attached like in this picture. if you have several layers, then change the direction each time.
/Viktor
 Attachment: 10.04 KB
Johan S. Moen
PostPosted: Mon 09 Nov, 2009 5:13 am    Post subject:         Reply with quote
If you are going to be training regularly, I wouldn't bother with a planked construction. Plywood holds up better, and no one can see it under a canvas covering anyway. Even plywood gets wrecked often enough, but it'll usually last a good season or so.
However, a planked shield is much nicer for displays and perhaps showfights.
Johan Schubert Moen
Elling Polden
PostPosted: Mon 09 Nov, 2009 5:42 am    Post subject:         Reply with quote
Cloth covered ply is, from extensive experience, your best choise for a figthing shield.
For an exact replica, 6mm linden boards covered with rawhide would be ideal. However, this moves your shield firmly from the hobyist price range, and requires a lot more time, tools and experience.
Kristian Fagerström
PostPosted: Tue 08 Feb, 2011 3:22 pm    Post subject:         Reply with quote
I am certain that I saw a source that mentioned linen facing, but I cannot seem to find it.
Help?
Page 2 of 2 Reply to topic
