Langes messer
I have a question: what was the German Langes Messer? It looks like a falchion, but I'm not sure. Thanks.
The Langes Messer was much longer, being a true two-handed weapon. The blade had more of a dramatic crescent curve like that of a shamshir. Other than that, the grip, tang, cross were all very similar to the Grosse Messer.
As far as I know from books, the interwebs and my instructors, the terms "Langes Messer" (long knife) and "Grosses Messer" (big knife) are used interchangeably, they usually mean the same one-handed sword with either one edge or one and a half (i.e. a short, sharpened false edge). The really long, two-handed variant is commonly called "Kriegsmesser" (war knife).
Cheers, Peter
I agree with the above. There's no knowing if our ancestors used clearly-defined terms for knifre-like weapons, but there's a thing. Usually 'langes' means the handle can accomodate two hands. No more, no less. Kriegsmesser is the name I'd associate with the true two-hand weapons of 1490+
The difference between the Messer and Falchion is mostly related to the handle construction. A Falchion's handle is built in the same way as other swords. A Messer's handle consists of a tang sandwiched between two slabs of wood and riveted together, just like a modern steak knife handle. The other big idfference was their intended use: A Falchion was a chopping blade manufactured for war. A Messer was a large, machette-like knife that was employed by all levels of society as a tool but was easily adapted to self defense.
The Difference Between a Messer and a Falchion?
Same here, but there still are a lot of folks who use different names. Nobody is right in this point I think.
Most of the native German speakers I know use the term "langes messer" to describe the "hand and a half" version, but as mentioned above, the terminology wasn't very specific in period. I'm not aware of the term "grosse messer" being used as a technical term in any period sources (though that doesn't mean it wasn't, I've just only heard modern people use the term).
ok, then. So, what are these guys using? http://www.youtube.com/watch?v=38sVdx7nzhQ
Not to sound like an @ss...
They are using Langes Messers.
Look at the hilts, they are longer the grip of the hand.
David
couldn't really see the handles, actually. I thought they were falchion.
So, a messer has more to do with the grip than it does the blade. Interesting. Thanks.
It's a fine line. Also considered sometimes is the method of construction for the blade.
M.
I agree on the bit about handle construction, but looking at the cross guard, it looks more as if it was intended as a weapon, rather than just a tool which could fill the role in a pinch. A crossguard like that would not help it's usage as a tool, and may even get in the way.
Of course, it is possible that they were much like a seax in that they were made and used both as tools and weapons. It's also possible that the grosse messer was just a variant of a falchion.
