Forum Index > Historical Arms Talk > The Cawood Sword Reply to topic
Bruno Giordan
PostPosted: Thu 13 Aug, 2009 2:27 am    Post subject:         Reply with quote
Michael Pikula wrote:
Adam S. wrote:
I'd like an opinion.
Does it look as if the pommel may have had wire work? There are two fairly pronounced pits near the base of the central lobe that look like they could have either been recesses for then ends of wire, or just deep pitting.
I can't remember where I got this image, but I believe it's from the Yorkshire Museum. Same as the first.
I think the holes are actually pitting from where it corroded through.... I could be off though.
from the holes there is apaprently some light coming iout, it appears as an hollow pommel, a fusion likely,: this could explain why the balance point is so far off the hilt,, along with a lack of distal taper.
It would be fundamental to have some distal taper data for both blade and tang.
Dave W.
PostPosted: Fri 14 Aug, 2009 10:55 am    Post subject:         Reply with quote
Thanks Nathan
PostPosted: Fri 14 Aug, 2009 4:19 pm    Post subject:         Reply with quote
Given the kind of discrepancies/possibilities in different datings in the background of the writing, find, etc., I am wondering if anyone considers it possible that this was an older blade that was later rehilted?
Peter Lyon
Reading list: 39 books
PostPosted: Sat 15 Aug, 2009 2:04 pm    Post subject:         Reply with quote
Just a further note about the Cawood sword, the pommel is actually very thin (maybe only 8-10mm in the detail area and a little thicker in the base of the pommel) - so the holes could well be showing the top of the tang inside the pommel. Whether they are corrossion, or were for wires to be pushed into, there is no trace now to confirm either way. Before anyone asks, I can't post the photos I have as I had sign an agreement that requires permission from the museum before I publish them anywhere.
This pommel is more about decoration and leverage for the hand, than counterweight, it would weigh no more than 150 grams (about 6 ounces). One of the reasons it felt so good in hand, I think, is that the short grip (85mm) held my hand snuggly between the cross and pommel base, and probably allowed me more leverage with the sides of my hand than if my only contact was the tang. Another aside, I have long fingers but an average sized hand, so there would not be much room to wear any sort of glove with this grip without feeling pinched.
Still hammering away
Adam S.
PostPosted: Sat 15 Aug, 2009 2:15 pm    Post subject:         Reply with quote
Thanks for that, Peter! More information is always welcome!
Page 2 of 2 Reply to topic
