James R.Fox
Posted: Fri 02 Jan, 2009 8:24 am Post subject: |
Sir- that is what was so cool about the antikythera machine. We don't know only one was built, and since so much background thechnology went into it,( multiple observations from various points and times of year, development of reliable gear trains, the hand crank, which is not at all obvious,not being re-invented in Europe untill around 1000 ce) I very highly doubt only one was. I would agree the sailor's guild or merchants guild or whatever kept it a trrade secret. Untill the invention of patent law that was common and the cause of much technical knowledge being lost.
Ja68ms
Eric Spitler
Posted: Fri 02 Jan, 2009 9:42 am Post subject: |
I always thought the Romans limited themselves quite a bit by not using stirrups on their saddles. I read somewhere that they knew about them but considered them unmanly. That probably reduced the effectiveness of a cavalry charge a lot.
"I never heard a corpse ask how it got so cold."
- Richard, The Lion in Winter
Xan Stepp
Posted: Fri 02 Jan, 2009 12:43 pm Post subject: |
First of all I do have to say that the Antikythera is one of the coolest things I've seen in a while, and thanks to Mr. Fox for bringing it up.
However, I can't help but ask if, in the discussion of the Antikythera, we are showing a huge cultural bias as well. While I wouldn't be surprised if more were built, I wouldn't be surprised if this were the only one. First of all, it's construction must have taken a huge amount of intellectual coordination or individual knowledge. Someone would need to preform the calculations, engineer the design, smelt the metal, construct the gears, test the design, and probably other things that I can't even think of. That is a pretty incredible skill set for one individual, and a remarkable team effort. Not that such an undertaking would be impossible, the Ancient Greeks did accomplish tasks far superior to what would have been required for the Antikythera. However, most of these accomplishments are also unique.
I also think that we, as modern people, see immense application for automated machines of this nature, but I'm not sure that it really would have been all that useful. First of all, it would have had limited applications in navigation. It would be easy to damage, and navigating using the Mediterranean can rely on landmarks much more than a lot of naval voyages. Also, who would use it? First of all you have to assume some measure of literacy was required to properly operate it, and then if something didn't work, you need someone to troubleshoot the problem. I certainly wouldn't want to trust my life or ship to a machine like this if no one was around who could fix it. So it seems only logical that the crew would still carry a navigator of some sort, who probably never actually did the math anyway, he was just so familiar with how the sky should be that he essentially functioned at the Antikythera.
So even if it had an non-navigational function, what would it be? The Wikipedia article proposed Astrology. But it seems to me that it would be about the last thing that you would want to mass produce. After all, if anyone could calculate star and planetary positions, you would loose half your job, and if you managed to produce an Antikythera, and someone else found out that you were using a machine, wouldn't you lose some of your mystique?
Anyway, my main point is that we love automated machines now, but I really question if such a machine would have really been more of a curiosity than useful for the Ancient Greeks?
Deyr fé, deyja frændur
deyr sjálfur ið sama;
en orðstír deyr aldregi
hveim er sér góðan getur.
Carl Pryor
Posted: Tue 06 Jan, 2009 3:13 pm Post subject: |
I was curious after hearing about the Antikythera device and did a little research. I seems the Greeks just before the Roman conquests was surprisingly close to an industrial revolution. They seem to have closed cylinder pistons, the clockwork and so forth. We cant judge accurately how close they came as almost all books and all but a handful of devices were lost. Some due to the loss of the library at Alexandria, other though not being copied (printing press limit from above?).
From what I gather the Antikythera device was not alone, (and that clock work devices were a noted artifact from some greece colonies), but it was an exceptional one for its time.
We have few works of note from heron, or his predecessors, but we do have fragments of works, were he describes things that he could not actually produce, as they required accurate screw threads in metal and metal gear chains, when they were now only able to produce threads in wood and friction drives. They were able to produce the metal screw theads and drives 300 years before, pre roman.
The Romans seem to have been limited by the ideal of 'romanitas' a roman-ness that should be aspired to. They readily copied items that were better then theirs that fit the ideals. Weaponry, armour, military training, and some architecture were chosen.
Other ideas did not fit, The Gaulish harvesting machine for instance, the use of gypsum based mortar as used in the east. The higher greek mechanics also were dropped. archimedes wonderful weapons did not get used across the empire. According to Suetonius (roman historian) a greek inventor (heron again?) offered Vespasian a mechanical device capable of shifting tons at a time vertically. Despite rebuilding large parts of the city, and needing to move vast amounts of stone Vespasian refused saying 'I have to feed the common people'. The historian approved it as a properly roman response.
We know Herons steam engine ended up opening the doors of a temple when a fire was lit, hidden under the floor so it could be seen that the door was opened it self. He was left making little more than toys, mobile theatres that stopped to do plays automatically, and a holy water dispenser that gave a measured amount when coins were inserted.
If you are interested the book 'Terry Jones' barbarians' by Terry Jones and Alan Ereira is worth reading, as it looks at the 'barbarians' around rome, and what they were able to do, as a contrast to most histories that repeat what rome tells us abut them and itself. It is 'popular history' but well done. The TV show accompanying it is rather rabidly anti-roman and not so balanced in out look.
Posted: Wed 07 Jan, 2009 6:59 am Post subject: Re: Cultural Paradigms That Limit Military Technology/Effice |
James R.Fox wrote: | Sirs-I was reading some Roman history, and noticed the problem that occured over and over, namely, that Legions and their supplies could only be moved to a trouble point at the walking speed of man and mule. |
Remember that their "walking speed of man and mule" was already faster than the traveling speeds of most pre-modern historical armies--especially when they're making full use of the logistical depot system provided by their network of forts and fortified cities.
Jean Thibodeau wrote: | The Renaissance wasn't greatly more advanced than the Romans in their time |
Um...really?
Better metallurgy, much more productive agriculture, greater variety of weapons, sturdier and more seaworthy ships (especially for very long voyages)...put together, these and other medieval/Renaissance inventions probably outweighed the few things that the Romans had but their Renaissance descendants didn't.
Bryce Felperin wrote: | In many ways this labor issue also probably applies to Chinese and Native American cultures who didn't eventually develop automated systems for labor saving use. No need, so why bother. Traditional means work so why develop new means if there is no shortage of labor to do the job. |
This actually makes perfect economic and political sense. Developing more capital-intensive means of production could put hordes after hordes of slave laborer out of employment, and just imagine the effect on Roman society of thousands upon thousands of disaffected, unemployed slaves who no longer had work that could distract them from thoughts of rebellion.
Xan Stepp wrote: | I've also thought that ramming was a horrible idea. You risk damaging your own ship, loosing your crew overboard, and you will certainly damage the enemy ship. Ships represent a considerable investment in both time and money, especially as good ship building timber was becoming more and more scarce toward the end of the Viking Age. It makes a lot more sense to try and capture a ship than to sink it and risk sinking your own. |
Actually, even the ancient Greeks--despite their reputation for ramming--also seemed to prefer capture to sinking. The ram can certainly be used to shear off the opponent's oars rather than breaking his hull altogether, and even a staved-in hull wasn't guaranteed to sink since ancient galleys up to trireme size sometimes didn't have enough ballast to sink them even when heavily damaged and waterlogged.
Eric Spitler wrote: | I always thought the Romans limited themselves quite a bit by not using stirrups on their saddles. I read somewhere that they knew about them but considered them unmanly. |
Where did you read that--and what kind of stirrups? The earliest stirrups were just non-rigid loops, probably made more as an aid to mounting rather than as riding devices as we know them today, and there was often only one stirrup on the near side of the horse (not two as in the modern configuration). I can understand and fully sympathize with people who found such stirrups "unmanly" because they imply that the user was too lazy or too unskilled to vault directly into the saddle without the stirrups' aid.
Carl Pryor wrote: | archimedes wonderful weapons did not get used across the empire. |
Because some of them might have been mythical, and the others were probably improvised one-off gadgets that worked against the Roman siege of Syracuse but didn't have more generalized practical applications elsewhere? And let's not forget that the Romans won despite being on the wrong end of those weapons....
Quote: | According to Suetonius (roman historian) a greek inventor (heron again?) offered Vespasian a mechanical device capable of shifting tons at a time vertically. Despite rebuilding large parts of the city, and needing to move vast amounts of stone Vespasian refused saying 'I have to feed the common people'. The historian approved it as a properly roman response. |
And a modern economist would probably approve of this extremely sound macroeconomic (and political) decision too!
Posted: Wed 07 Jan, 2009 7:33 am Post subject: Re: Cultural Paradigms That Limit Military Technology/Effice |
Lafayette C Curtis wrote: |
Um...really?
A probably right as I don't have a comparative list of technologies used in the Ancient World technology by technology.
( And was making an over broad generalization ).
Maybe , the Renaissance did have that " spark " of scientific inquiry that slowly led to the acquisition of new knowledge and the application of new knowledge in practical ways that the Romans didn't take advantage of ?
The Roman period as well as the Renaissance do seem to me to have been better organized for large projects or industrial production than the periods in between ? Some types of " factory " kinds of activity and logistics and the ability to take on large projects.
The point being that the Romans could have in theory progressed to a technological society but didn't for various reasons cultural and maybe just the lack of the catalyst of one or more great minds bringing on the idea of scientific progress and the political and economical motivation/imagination to want to go in that direction.
Oh, one could say the same for the Chinese or even the Egyptians: Technological advances like we have seen from the 16th century and accelerating to today could have happened any time a society got sufficiently " organized " and at a technological level similar to Ancient civilizations.
One could also wonder if reaching the level of the Ancient civilizations could have happened at any time since the Neolithic or in the opposite direction human cultures could have stayed at the Neolithic level for many more millennia than it actually did i.e. barring some accidents of history or tipping points we might still be living like we where 50,000 years ago.
Gary Teuscher
Posted: Wed 07 Jan, 2009 8:59 am Post subject: |
One thing IMO was the lack of many earlier middle ages armies to use trained better morale type footmen.
This was mostly a social thing, the focus was on the mounted knight being king of the battlefield.
Many foot armies that were properly trained and equipped could handle chivalry - Flemish, Swiss, even the English in the latter period of the middle ages.
The age of Pike was about 14 hundred years after the early age of pike with the Hellenistic kingdoms - It was not technology but socialissues that limited the value of the middle ages footmen.
I think it's easy to go overboard here - the feudal infantry in general was a bit more valuable than they are often given credit for - they were not purely levies and there were some that were more professional. But the still did not give the footman status compared to a mounted type, and this is much of what IMO was somewhat of an issue with morale. The warriors warriors with good "morale" throughout history were those that either were a bit of an "elite". like many of the mounted types, huscarls, Varangians, or ones that were "part of something", thinking of early expansion Islamics for one. Roman Legionairres had that "citizen" status. The Hussites were part of a religous movement. Alexander's pikemen were called "foot companions" of the king. Just the terminolgy there says something to me
It's the lack of social position that often makes one want to fight harder and not run away. Knights stood to lose much if their side lost. For many serfs it was just "same situation, different master". Putting the foot to a better status, or perhaps taking a bit of the kinghts status away would have led to a more effective infantry. Making these a more regular foot type with better drilling and training would have been a big difference maker also.
Harold R.
Posted: Wed 07 Jan, 2009 9:55 pm Post subject: |
Currently we can see some of this in our own culture here in the US.
Firearms ownership is often looked down on by the media and there are constant attempts by our government to make their use and ownership even more restricted.
Select fire weapons are heavily regulated to even own. If you want to actually develop some of your own you've got all kinds of hoops to jump through.
In my opinion, this could be acting to restrictt the development of small arms that could be of use to our military.
For example, I've kicked the idea around of a relatively compact submachine gun (PDW) firing a flat shooting round for use out to about 200 meters or so maximum. It would be competition to the P90 but vastly more easy and cheaper to produce.
We're talking stamped steel and polymer construction, even using furniture from current production weapons where possible. I'd use fire control parts from the M-16 series but with the deletion of the semi-auto function - it's not at all hard to fire one shot at a time on an FA weapon by just letting go of the trigger. Sights would be a simple flip type aperature set for either 100 or 200 meters and dovetailed in for windage adjustment. The action would be blowback - no expensive machined locking system needed. This thing would be functional and so cheap that if you broke one you could literally just toss it and get another one.
But most of us can't develop an test such a weapon because of laws, hassles, and red tape.
So our armed forces may be losing out because of this (or maybe not).
Granted, this is getting off the subject of historical weapons.
But it is an example of a cultural factor that could be restricting military weapons and tactics.
Odds are that in a thousand years that someone would be able to put that together if they were studying our culture - with all the stuff that we write down something is bound to survive to help future historians understand why we did what we did.
But the civilizations of the past didn't have this luxury. Even those with writing still didn't have anywhere near the same amount of stuff written down that we have today.
So...
We spend a lot of time guessing about it.
M. Eversberg II
Posted: Thu 08 Jan, 2009 5:21 am Post subject: |
We, as a modern "culture", tend to write down stuff our ancestors would likely have thought trivial. This is probably because writing has become a survival skill.
I too wonder why it took so long to invent the printing press. As a child, before I was even aware what a printing press was, I was practically doing similar things with letter blocks and paint, so I wouldn't have to get paint all over myself. Why the Greeks didn't look into it is weird.
My largest reason for its delay is that steel work had to become reliable first. I'm sure making the letters out of wood would kind of suck, as it would absorb the ink and become soggy. The letters would have to be steel (harder, more durable than iron) which is better used in your military to defend against (and offend against) those outside your borders. It's also expensive.
But, that's my idea, and I've noticed I'm normally wrong about such things.
M.
This space for rent or lease.
Vincent Le Chevalier
Posted: Thu 08 Jan, 2009 5:35 am Post subject: |
M. Eversberg II wrote: | I too wonder why it took so long to invent the printing press.
My largest reason for its delay is that steel work had to become reliable first. I'm sure making the letters out of wood would kind of suck, as it would absorb the ink and become soggy. The letters would have to be steel (harder, more durable than iron) which is better used in your military to defend against (and offend against) those outside your borders. It's also expensive. |
Hmm I don't know if steel really is the most appropriate metal for this kind of thing. There were other metals that could have been used because they can be melt and molded, lead for example. It does take some research in alloys to reach the suitable properties (see http://en.wikipedia.org/wiki/Type_metal), but I don't think it was in direct competition with military metal resources.
Vincent
Ensis Sub Caelo
M. Eversberg II
Posted: Thu 08 Jan, 2009 8:28 am Post subject: |
Quote: | Although the knowledge of casting soft metals in moulds was well established before Gutenberg's time, his discovery of an alloy that was hard, durable, and would take a clear impression from the mould (because it did not shrink as much as lead alone when cooled) represents a fundamental aspect of his solution to the problem of printing with movable type. (His other contributions were creation of inks that would adhere to metal type and a method of softening handmade printing paper so that it would take the impression well.)
The enormous effort to create an alloy with the characteristics needed in an ideal type metal is often underestimated. |
Well, that right there is an ace example of multiple different technologies coming together to form a larger project I'd say.
M.
Xan Stepp
Posted: Thu 08 Jan, 2009 8:58 am Post subject: |
| I'm glad to hear that, ramming has never really made much sense to me.
As for evaluating the past, I tend to think that we buy into the Renaissance idea of the "Dark Ages" and that "Rome was so great" a lot more than we actually should. The first thing to remember is that Rome did fall, so it indicates that at some level the invading tribes had an edge that was not available to Rome. A large part of this was social, not technological, but frankly I'm glad that the old Roman social order fell, I wouldn't have wanted to live in it.
Secondly, we have a huge tendency to judge a culture by their material remains. The Romans were clearly brilliant engineers, and many of their feats were not able to be duplicated until the 20th century. However, after having spent a considerable amount of time in Northern and Southern Europe, I do have to say that the same sort of public building projects would not have been needed to the degree that they were in Rome. With the abundance of rain, there would not have been the same need for aqueducts, and a more forested terrain meant a greater abundance of smaller wooden structures which have long decayed in the moist environment. I do think that the Romans were more technologically advanced then their Germanic counterparts, but the Germanics did not have the same need to build large structures as the Romans.
Beyond that, there are plenty of examples of impressive building projects during the Middle Ages, so we know that they were possible, but I would assume that a less centralized economic structure made them less common.
And I would agree that the printing press was a remarkable serendipity of technology and social developments, and likely the most important of the past two millennia. However, in my opinion, another huge medieval development, and one which further contributed to the development of the press was the University. It is obvious today how hugely important the University has been, so I won't really comment on that. However, I wonder whether the printing press would have even been that useful a tool for the Romans who lacked any social institution of higher learning. Would they have seen it as a benefit to them?
Just my two cents.
Werner Stiegler
Posted: Thu 08 Jan, 2009 10:23 am Post subject: |
M. Eversberg II wrote: | We, as a modern "culture", tend to write down stuff our ancestors would likely have thought trivial. This is probably because writing has become a survival skill.
I too wonder why it took so long to invent the printing press. As a child, before I was even aware what a printing press was, I was practically doing similar things with letter blocks and paint, so I wouldn't have to get paint all over myself. Why the Greeks didn't look into it is weird. | Did books like the Bible even exist back during roman times? Books potentially anyone would like to own? I furthermore don't believe that the romans shared later generations conviction, that writing a book will grant them a form of personal immortality.
Plenty of roman learning and learning skills were about oral and mnenotic skills too - what's the use of writing everything down when a large part of your education dealt with how to remember and talk about things anyway?
Posted: Sun 11 Jan, 2009 1:05 am Post subject: |
Gary Teuscher wrote: | One thing IMO was the lack of many earlier middle ages armies to use trained better morale type footmen. |
That's because the man-at-arms (i.e. the "knight") was also the most powerful and arguably the most important form of infantry in early medieval Europe! Remember that a very large proportion of William's infantry force at Hastings was made up of armored cavalrymen who had to fight on foot because the Norman fleet couldn't transport their horses quickly enough? Or that the Battle of Bremule in the 12th century was essentially won by an infantry force made up of dismounted men-at-arms--arguably the only kind of continental European force that could be relied upon to resist the charge of their mounted counterparts in the open? And let's not forget that the Crusader force in the later stages of the first Crusade was largely composed of men-at-arms fighting on foot because their horses had been lost or killed earlier during the campaign.
Considering the economic conditions of the time, it actually made sense to rely on the men-at-arms to provide you with both heavy cavalry and heavy infantry capabilities, especially since armies tended to be elite and small. It was only in the later centuries, when the men-at-arms' equipment grew more complicated and expensive, that people found the need to recruit and utilize cheaper non-chivalric heavy infantry.
(Who were the Swabian swordsmen at Civitate, I wonder? They may be the most important exception to this rule.)
Werner Stiegler wrote: | Plenty of roman learning and learning skills were about oral and mnenotic skills too - what's the use of writing everything down when a large part of your education dealt with how to remember and talk about things anyway? |
Well, the one situation I can think of where writing skills would come in handy was recording your won or somebody else's speech!
Gabriele A. Pini
Posted: Sun 11 Jan, 2009 2:00 am Post subject: |
The write production of the Romans was huge, with a sort of industry (but without pressing) born from it: the "books" (but, in effect, rool of paper or papyrius) of celebrated authors, like Cicerone, were copied and sold across the empire, with even cases of piracy and names stealing.
This discussion is similar to the one born in my family: my brother worked for a month in a mission's hospital in Burundi, and returned with a very strange story: if the missionaries sell or give a sow to a family, with the intent to start a breeding, chance are high that this pig will be re-sold or eaten in one or two days. This even if the person comprehend that in a year he, or they, will suffer famine for this act...
The same applied for cats: there is a huge problems of rats, and the diseases connected, but if you import a cat from Italy, in one or two days they will eat it.
Why this?
A studious speak of the "absence of winter", or the need in the northest regions to accumulate and think for the snow stagion, while in old Africa food is available through the year, even if a bit scarce.
