Does anyone know what this is?
While labeled (I believe erroneously) as a falchion,
this weapon seems to be 'not quite' a dussack and
yet, 'not quite' a messer.
Thoughts?
-J.
 Attachment: 51.75 KB
Can you tell us what the scene is supposed to show? If it's a Biblical story or something from an ancient writer, it was pretty common to "classicize" or "anachronize" details to make the scene look archaic. So it might just be a made-up weapon that the artist thought of as looking old-fashioned. But I don't spot any glaring "neo-classical" bits, so maybe that's not the case.
Matthew
Hi Allen
My guess would be it would have been called a falchion or messer in period depending n where you originated and the local custom.
Check this topic for much good discussion The Difference Between a Messer and a Falchion?
Best
Craig
I'm trying to get answers to the questions on the painting.
In the meantime, how close or not is it to this photograph labeled Italian Falchion.
 Attachment: 32.48 KB
I forget where I got these.I've had them saved for a while but there are similar samples...
Thanks Craig,
That was a good lead (see below) and it seems to match the blade shape although the guards are different.
Number 3 is a falchion from the Zaton altar-piece dated 1430. Number 4 is a falchion fom the King Wenceslas Bible. Number 5 is the knife in the painting of the Madonna with St. Bartholomew and Margaret dating from about 1400. Number 6 is a soldier's sabre from the Rajhrad altar-piece painting of the Carrying of the Cross, dating prior to 1420. Number 7 is a falchion dating from about 1430 from the Hyrov votive altar piece, "The Madonna with the Donors". Number 8 is a falchion from the Rajhrad altar-piece painting of the Ressurection dating prior to 1420. Numbers 5, 6, and 7 may be called messers based on their hilt form.
 Attachment: 32.2 KB
Phil,
Those are swords made and pictured by Paul Macdonald,
Macdonald armoury,Scotland.
;) :cool:
The blade looks like a messer. The guard looks like a messer. The pommel looks like a messer. Why can't it be a messer? The pommel is the telling feature to me and is the main thing I look for to tell the difference.
The way I understand it, the difference between a messer and a falchion is in the hilt construction. Falchions have hilts constructed just like swords. Messers are constructed like knives. As far as blade geometry there seems to be a fair amount of overlap. But I imagine there is almost no difference in terms of handling, performance, function, etc. Shorter, curved blades seem to have been used across Europe throughout the Medieval-Renaissance period. They may have looked a bit different and been called different things at different times and in different places...but so did all the other swords shapes too.
