Forum Index > Off-topic Talk > making an historically accurate knife Reply to topic
Philip Montgomery
PostPosted: Sun 03 May, 2009 4:18 pm    Post subject: Re: pictures of blank after first stock removal         Reply with quote
Jared Smith wrote:
This is very thick. Look at one of your kitchen chef's knifes to get an idea of how thick a big knife for hard duty would normaly be. Depending upon your final decision on thickness, the taper for the edge is something of a science in itself. I like angles around 10 degrees as a compromise for toughness verses sharpness.
There is a fair guideline regarding thickness, angle, and relative toughness versus sharpness here. http://www.navaching.com/forge/design.html
Thanks. I thought it might be too big. Well, this is a learning process. Progress not perfection.
Philip Montgomery
"A broken sword blade fwipping through the air like a scythe through rye does demand attention."
Addison C. de Lisle
Likes: 27 pages
PostPosted: Sun 03 May, 2009 7:38 pm    Post subject:         Reply with quote
If you're looking for a good, inexpensive book to get started with knifemaking I would consider Tim McCreight's book "Custom Knifemaking".
http://www.myArmoury.com/books/item.php?ASIN=0811721752
www.addisondelisle.com
R D Moore
Reading list: 11 books
PostPosted: Sun 03 May, 2009 8:40 pm    Post subject:         Reply with quote
And here is another book that I have found helpful. It gives you some ideas for setting up a shop using fairly common and relatively inexpensive tools.
http://www.myArmoury.com/books/item.php?ASIN=0896892956
Artis Aboltins
PostPosted: Mon 04 May, 2009 2:19 am    Post subject:         Reply with quote
I have found this book to be a lot of help on my first attempts at knifemaking:
http://www.myArmoury.com/books/item.php?ASIN=0873644301
as it has most of the basic info one might need - on metals, on temperatures even on making forge suited for the needs.
PostPosted: Mon 04 May, 2009 2:25 am    Post subject:         Reply with quote
I've changed all the book links in this topic to link to Our Bookstore. Note that some of these books have reviews from myArmoury.com members as well as regular Amazon.com members. If any of you members purchase a book from Amazon via our bookstore, a small percentage of your money is earned by myArmoury.com.
R D Moore
PostPosted: Mon 04 May, 2009 6:13 pm    Post subject:         Reply with quote
Thanks, Nathan. Oversight on my part. The reviews have been instrumental on my book buying decisions in many cases.
Maurizio D'Angelo
Likes: 3 pages
Reading list: 3 books
PostPosted: Mon 04 May, 2009 7:56 pm    Post subject:         Reply with quote
ciao,
Knowing the steel is a good thing. Ask a lot of work and ruin everything for a hardening wrong is a serious injury. A tip, if you have to temper you, immerse in oil the knife vertically, this will avoid deformations. Making a straight knife after hardening is never a good idea. Crack. Confused
Good job
Ciao
Maurizio
Page 2 of 2 Reply to topic
