early medioeval infantryman hands protections
taking a look at the iconographic source for the early medioeval period ( XI - XIII cent.) i have never found
a depiction of armoured gauntled of any sort. conpared with later period ( XIV - XV cent.) the early medioeval infantryman
or common soldier was depicted always without hands protections. i believe that it's quite strange because the hands are a
very vulnerable target and even a light wound can reduce or stop the fighting ability. ii's true that often one of the hand is
covered by a shield of some sort but the hand holding thr weapon is , in my opinion ,quite vulnerable.
What do you think about ?
All sorts of hand protection are pretty expensive. I think it was about the 13th-14th century that we that sort of thing becoming the norm for the warrior class, who also served as infantry when needed.
Remember, the Romans didn't issue hand protection, except in one offensive against the Dacians.
M.
Presumably they felt the hands were not all that vulnerable. If a shield is used, the left hand is as safe as it's going to get. The right is holding the weapon, and only comes out very quickly and briefly when a blow is struck. At which point the opponent is REALLY more concerned about the weapon than the hand!
For thousands of years, most ancient warriors fought without hand protection. Even the Roman manica didn't necessarily cover the hand, only the arm (though some did have plates over the hand). In other ancient cultures, hand protection is very rare indeed, even when arm guards are used by nobility and other wealthy warriors. I certainly agree that getting hit on the hand is a bad thing!! Darn delicate things, and not something you want to do without. Just doesn't seem to have been their greatest concern back then.
I have heard that Scottish soldiers in the early 14th century were supposed to have armored gloves of some sort, but that's not from a primary source and I don't know if there are comparable requirements in other countries. But it's about the earliest that I know of for *common* hand protection.
Valete,
Matthew
The fighters in 1.33 wear gloves, but these do not seem to be armoured, merely the white (kidskin?) gloves worn by noblemen at the time.
However, it is definitely better than nothing.
