Kirk Lee Spencer
Posted: Thu 02 Oct, 2008 11:50 am Post subject: |
| Darrin Hughes wrote: | Thanks for keeping this alive chaps And thanks for the article about the Ulfberht mark. I'm not sure how this ties in with the Type L discussion... |
Hey Darrin...
I had the same thought. There does not seem to be a direct connection to Type L forms and Ulfberth blades. I appreciate Richards comments that it does relate to the issue of sword find distribution. And I think it is true that export could lead to a higher concentration of a sword type in an area where it was not produced. As per the article, it is not so much that there were more swords in regions of export but rather, in these areas pagan burials with burial goods, these types were more commonly preserved than in areas of production with more Christian burials without burial goods. But the point still holds in relationship to type L forms. They may have originated elsewhere but appear in Scandinavian areas because of the higher incident of pagan burial with burial goods.
There may even be a more direct relationship between studies of Ulfberth blades and Type L forms. I have thought about making a nice type L sword with an Ulfberth blade, but could not find an example in an original find with L type and also and Ulfberth blade. It was reassuring to see that Anne Stalsberg's chart of Ulfberth blade finds also includes no Type L form.
So it could be that the very lack of connection may be a way of connecting them. For instance: If Type L originated in scandinavia which clearly had access to Ulfberth blades, should we not find at least one Type L form with and Ulfberth blade. On the other hand, if type L arose in Anglo-Saxon England with little connection to Ulfberth blades then it would be more reasonable that no Type L would be found with an Ulfberth blade. Just a thought...
Also, I find it interesting that Petersen has very detailed divisions of hilt types that, to me, seem very similar such as D, E, V, W, and yet does not make distinctions in type L forms which show, IMO, much clearer variation. (not sure why this it the case.) As I see it there are what I called "lobed" types and "saxon" types. Recently I ran across a sword published in Laking which seems to be somewhat intermediate between these two forms.
Great discussion guys...
ks
Attachment: 96.38 KB
Attachment: 78.83 KB
From "The Vlfberht Sword Blades Reevaluated. " By ANNE STALSBERG
Attachment: 99.02 KB
Red Squares Types with Ulfberth blades from data in "The Vlfberht Sword Blades Reevaluated." By ANNE STALSBERG
Two swords
Lit in Eden’s flame
One of iron and one of ink
To place within a bloody hand
One of God or one of man
Our souls to one of
Two eternities
Darrin Hughes
Posted: Fri 03 Oct, 2008 5:53 am Post subject: |
Thanks Kirk. The number of different variants of type L hilts is one of the things that had me wondering about origins. In the Davidson book there is the rather hopeful comment that maybe one day we might be able to identify a single workshop where these were turned out, as though we were looking at an Anglo-Saxon cutler or silversmith working in an Ulfberht-like fashion. But to me this is good evidence of a number of workshops hilting up blades in their own style. I've already mentioned that I have no problem with the idea that some of these hilts were created by Saxon craftsmen, as you have pointed out the high peaked variant seems to be the best candidate for this as all of the known examples seem to have the elaborate Hiberno-Saxon decoration which gets labeled as Trewhiddle. I have a slight problem with this as, from what I've seen, the Trewhiddle hoard includes pieces which display at least 3 different styles of decoration, but the interlocking Celtic/Saxon designs which appear on these sword hilts is in there so I'll not over-complicate matters by going over that here.
Also, the lack of Type L's mounted on Ulfberht blades doesn't worry me too much. Not all of the blades that came out of Frankish workshops were Ulfberhts, and some of the type L's have been found with blades that bear simpler marks, such as crosses and omega signs. The river Witham sword that you have included a picture of has LEUTRIT in the blade I believe, and with the second T up-side down, so possibly another one in favour of an illiterate smith, this one also has a thicker lower guard with Copper-inlaid diamonds which I certainly wouldn't consider to be Anglo-Saxon decoration. A really nice example that came out of theThames and is dated to the early eleventh century, the time of the second major scandinavian incursion, has INGELRII in the blade. This one is beautifully done as well, maybe INGELRII employed better copiers , and doesn't have the high central peak.
What I've been trying to get at here is who were these swords actually for? Who was using them? If a sword consists of a Frankish blade, and is re-hilted by a Saxon craftsman, for a customer from Norway. Does that make it an Anglo-Saxon sword? This is the sort of scenario that I believe would have been entirely possible given the conditions that existed in North-Western europe in the 9th and 10th centuries, for reasons that I've tried to outline in the previous posts. At best I would have one Type L variant in an Anglo-saxon style, and even then I would not neccesarily say that it was the orginal type L, but rather a more elaborate version of a simpler Frankish, or possibly Scandinavian design, brought in by the invading Vikings.
Darrin.
Darrin Hughes
Posted: Fri 03 Oct, 2008 8:10 am Post subject: |
Hello Richard, I thought I should comment seperately on the Anne Stalsberg article rather than lumping everything together in another big post
Whilst I'm not dismissng the article out of hand as it's fairly obvious that it has been well researched, I would point out that it is still very speculative in the two main areas, ie, who was making the swords, and how they were being distributed. The author makes it perfectly clear that she is trying to put forth one possible explanation, based on what is known of Frankish culture, which is exactly what I'm trying to do with this thread, based on what we know of Anglo-Saxon and Viking culture in the 9th and 10th centuries. The whole argument about the Ulfberht workshop being attached to an Abbey is based entirely on the idea that priests could read and smiths couldn't. But I'm pretty sure that a respected and wealthy smith could afford somebody to write his name down for him and he could have also afforded slaves, so it is really no more than one possible explanation, albeit a well thought out one. Again I'm not saying that Paul's explanation is any more correct than Anne's, being a smith himself he is probably more likely to favour an arguement that favours smiths, however until somebody digs up the remains of a Frankish abbey dated to the 8th-10th century, with a dirty great smithy associated with it, or turns up some detailed records of transactions, then it is still just informed speculation.
By the way, the reason I thought of Paul is because of the mention of the sword with Ulfberht on one side and Ingelrii on the other. Paul was the person who first told me about this sword, as it, or one like it, is in a Museum in Wisbech close to where he lives. I know that he was trying to arrange a viewing so that he could get a closer look at the welding of the letters, I'll have to ask him if he had any joy. Also, the Anne Stalsberg paper makes it quite clear that she won't be going into the metallurgy and forging techniques, whereas this is something that Paul has spent a good few years looking into for the purposes of his work.
I think where the paper gets really tied up in knots though, is over the issue of distribution. I know that this is where you are trying to draw a parallel between Frankish blades and type L hilts, but I think that there are some fundamental differences between the two. For a start the sheer volume of Frankish blades that have been found would indicate to me a large trading network. If all of the Ulfberhts that have been found are only a fraction of what actually existed, and if in turn these are only a fraction of the total number of blades, taking into account the Ingelriis, and other marked blades, along with all of the un-marked ones, then that is a lot of blades. The idea that they might all have been taken as plunder doesn't say much for Frankish security,especially as we are looking at presumedly small, opportunistic, bands of Viking raiders stealing large quantities of weapons, over a long period of time, from the best organised empire in christendom at that time. The idea that they might actually be organising large scale raids, specifically targeting Fankish military barracks, would I think be particularly alarming to the Frankish hierarchy, and not something that they would have been prepared to tolerate for any great length of time.
I know that there are good references in the article to records saying that weaons should not be allowed into the hands of merchants, but to me that would imply that maybe the Frankish arms trade was state controlled. Something that would have probably appealed to the Carolingian mindset. After all if there's money to be made from selling arms why do it indirectly through taxes, when you can swell the royal coffers doing it directly through your own agents. I'm sure that the idea of financing your own military by selling equipment to the enemy is not a modern one, and it's not as though you would even have to sell them the good stuff. We know from studies that have been carried out on blades found in scandinavia that a lot of them weren't very good at all, with poor welds, cold shuts, microfractures, etc. If the Franks were mass-producing blades, then I'm sure a lot of them would have been deemed unsuitable for their own use, but perfectly acceptable for trading with illiterate pagans, who may never know that they've been sold junk until it's too late. After all how good does a sword need to be to cut down civilians running in the opposite direction whilst your mates set fire to the thatch?
As opposed to this kind of mass-production for profit, and as has been pointed out already, the manufacture of hilts seems to have been much more of a cottage industry. If a type L sword hilt turns up in the Ukraine with Anglo-Saxon decoration on it, then I'm quite happy to accept that it probably came from an Anglo-Saxon workshop, but this is only one of a number of different variants of the type, and not neccesarily one that was ever made with a Saxon customer in mind, and certainly not for the puposes of international trade. That is why I don't think that the distribution of Frankish blades is particularly relevant in a discussion about one particular type of sword hilt. Lots of Frankish blades ended up with hilts in all sorts of different styles. I'm just interested in why one particular type of hilt ended up with the blanket designation of Anglo-Saxon, when I don't think the evidence, either archaeaological or literary, warrants it.
Darrin.
Richard Hare
Posted: Sat 04 Oct, 2008 7:45 pm Post subject: |
Good evening, Darrin.
If Paul gets a chance to examine the Ingelrii sword, I am sure his findings would be of interest to us all!
The large amount of Frankish swords in the "pagan north" cannot be attributed to plunder, I am sure.
The Norse were great traders, and had links with many lands, and I'm sure a middle-man could be found,... so many swords could possibly come indirectly into the Nordic lands
Do I see a glimmer of light at the end of this somewhat depressing tunnel?
You wrote;
| Quote: | | If a type L sword hilt turns up in the Ukraine with Anglo-Saxon decoration on it, then I'm quite happy to accept that it probably came from an Anglo-Saxon workshop, but this is only one of a number of different variants of the type |
Here I must ask what variants of this type you mean?
The type L appears to have been produced from approximately the year 850 to 975AD and had Anglo-Saxon decoration.
To me, this Is the type L.
Other "close relatives, are all younger, (like the types P, Q, S. Y, & Z.)
Some of these may have been Nordic "versions" of a type L but are different in design and decoration. (and came a bit later)
Were you meaning any of the above, Darrin? If so, I agree with you! .... But must stick to my guns when it comes to the "real" type L being Anglo-Saxon.
A plain hilt with merely curved guards could have been made in Norway, as some undoubtedly were. These I would view as copies of the type L, as they came later than the first Anglo-Saxon versions.
| Quote: | | I'm just interested why one particular type of hilt ended up with the blanket designation of Anglo-Saxon |
I can only speak for myself here, but Only regard a sword a type L, if it is of the type L form, And has Anglo-Saxon decoration.
This may be over-simplifying things, but I don't think it is safe to call a hilt a type L just because it has curved guards, unless it was made in the earlier years, before the types P, Q, S, etc, were being produced.
All the best,
Richard.
Boris Td
Posted: Sat 16 Apr, 2016 9:06 am Post subject: |
This is not the first time i hear about this. Here is a quote from a book i have been reading (Swords of the Viking Age by Ian Peirce)
" The sword under examination is a Petersen type L and it has been stated so much in the past that this is an English hilt type. It is true that few examples have been found in the British Isle and England, in particular, but not as many as in Norway. Jan Petersen list fourteen in his sword Register and they are spread over a wide area of find places It is of mid ninth to mid tenth century.
Occasionally perhaps even more frequently, and especially in the light of new data, we should be open to adjusting our thoughts and opinion on certain topics. I, therefore, believe that we must now consider Petersen type L as Viking (Scandinavian type hilt frequently found (and therefore likely popular) in England
A. Marzé
Posted: Tue 08 May, 2018 6:11 pm Post subject: |
Wouldn't the attached sword from Russia be considered a type L? The decorative style does not appear to be Anglo-Saxon, but rather overtly Scandinavian.
Attachment: 161.76 KB
mēter emē ta men hopla theos poren hoi' epieikes
erg' emen athanatōn, mē de broton andra telessai.
nun d' ētoi men egō thōrēxomai.
