Stephan Hall
Posted: Fri 29 Feb, 2008 4:44 am Post subject: |
Adam your problem of brittleness of the finger seems to come from the wax, it looks like stearin wich is not the first choice for modelling.
Beeswax is better but damn expensive and is sticky. Best thing would be a mixture of both wich is sold as modeling wax wich is recommended for lost wax moulding with bronze.
Another method would be to form it out of another stuff like clay and make a silikcon form around it then remove the negative form and cast the form with wax to get a positive modell.
By the way how long do you want to make it more like a double handed mace ( less than one meter ) or like fußstreithammer or luzerner hammer ( up to 1.5 meter or longer).
Adam Bodorics
Posted: Sun 02 Mar, 2008 4:14 am Post subject: |
Hmm, thank for the advice about beeswax - I think I can get some from one of my relatives. Modeling wax is unheard of here, as far as I know, just like lost wax casting... I'm very, very glad that I found a guy who knew what I was talking about in Debrecen...
We thought about silicon, but so far we couldn't get any.
As I'm a big fan of the poleaxe, it'll have about the same size, even as the head is completely different - I think I'll make it cca 175cm from bottom to knuckles.
BTW, I'm finished with the "'nail", but I'll add it to the form only after all else is done.
Anyone else, opinions?
Stephan Hall
Posted: Sun 02 Mar, 2008 8:48 am Post subject: |
adam lost wax technique is to form the thing you want to cast out of wax then you bild the form around it out of sand or a ceramic mass ( goldsmiths cast like that) and then you have to melt the wax out. so the form is now hollow and the metall can be cast in it. how do you want to do the casting, have you casted brass or bronze before?
Addison C. de Lisle
Posted: Sun 02 Mar, 2008 3:52 pm Post subject: |
If you're having problems with your wax and can't get a different hardness, you can carve the finger out of wood and coat it with wax instead - it'll all burn out in the end Basically, if it burns, you can cast with it. Just make sure it doesn't absorb water out of your casting investment by coating your object with shellac, or wax.
www.addisondelisle.com
Adam Bodorics
Posted: Mon 03 Mar, 2008 1:32 am Post subject: |
I think we have a problem from different languages... I know what's lost wax, but I've found only one guy in Hungary so far who also knows it. And he'll do the casting itself, as I only have a very, very small garage as a shop, with a piece of railroad track as an anvil, two hammers, a drill and an angle grinder, and almost no room left with those.
hmmm, wood seems like a good idea, I think I'll try it later.
Thanks
Stephan Hall
Posted: Tue 25 Mar, 2008 5:29 am Post subject: |
Hello Adam, how far has your Hammer developed? Have you solved your Problems.
I`mloking forward to hear from you !
Adam Bodorics
Posted: Tue 29 Apr, 2008 5:17 am Post subject: |
Ahh, at last, we have internet at home, so I can post more often... now we only have to get a router as my dearest one keeps stealing the cable.
It turned out that the guy who would have made the casting only knows a place where they can cast wax. I contacted them and I was informed that they can cast high carbon steel as well as stainless, bronze, copper, etc... so I dumped the bronze body-steel attack surfaces idea, and added those from wax and it'll be one piece out of steel. The wax itself is complete, I'm thinking about adding a bit more socket lenght, I now only have to get enough money for it. If I'd order more than 50 castings, it'd be about $100 each, but for a single piece they'll charge more than $250.
As it is purely a personal piece, I won't rush to get the money, but when I have enough spare, I'll have it made and post the pictures.
Nathan Spence
Posted: Thu 08 Jan, 2009 7:05 pm Post subject: |
Have you gotten any closer to this project. I would really love to have a hammer of this style. I remember seeing one like this for sale somewhere, but cannot find it now. Perhaps there would be more interest here and you can put together an order for some.
Nice work.
Spence
Adam Bodorics
Posted: Fri 09 Jan, 2009 5:23 am Post subject: |
Sadly, casting was already very expensive when I started this project, and it only got EVEN MORE expensive here, so the project is stopped. I already reused the wax for a number of quillons and pommels I had to finish, so when I'll have enough spare money to fund casting such a big item (it would've been a personal piece, which means that I'm not willing to put much money into it), I'll remake it. I learned quite a lot of things while making it, but that's all for now. I'm a bit sad about this, but hey, I made washers from my first full harness, so I'm used to recycling.
