Rapiers with spring-loaded blades
It certainly seems to fall into the "gimmicky" category, but does anyone have more information as to their actual use? Is there any documentation or accounting of such a weapon actually being used in a duel or combat? Given the lavish decoration on this piece, and the intricacy of the mechanism, one could assume it a showpiece of both the craftsman's skill and the owner's ostentation, but were they ever more than this?
From the Rüstkammer, Dresden:
"The South German rapiers with spring-loaded blade from circa 1570 are equipped with moveable blades which thrust forward and can be pushed back with a hollow metal handle. The blade is moved with two gears which take hold of the lateral cog on the ricasso. When pushing back the blade, the springs are tied around the core of the gears and thus cocked. When using the trigger, the blade springs forward some six inches."
Six inches is an awful lot of potential reach advantage to have at the squeeze of a trigger, but I'd think it'd be pretty obvious to see that one's opponent's weapon was so equipped...
 Attachment: 101.89 KB
You may find more information in this article.
Some combination weapons were probably only mechanical curiosities. Some may have seen use. While they are featured in so many museums, I've not read of accounts of their use, actually.
