Forum Index > Historical Arms Talk > original 15cchainmail ring dimensions Reply to topic
Michal Plezia
PostPosted: Fri 12 Oct, 2007 8:42 am    Post subject: original 15cchainmail ring dimensions         Reply with quote
Hi
I need some info about basic dimension of average ring in 15cent mail.The most important is thickness of the ring.Some say they could be less than 1mm thick...others that average was 1.5mm.I tried to find some reliable studies...but I could't find anything credible.What is your opinion?
www.elchon.com
Polish Guild of Knifemakers
it that is the only truth.
Fabrice Cognot
PostPosted: Fri 12 Oct, 2007 5:33 pm    Post subject:         Reply with quote
Quite frequently the rings were of flattened oval - or rectangular or D-shaped, if punched - section.
The chainmail I documented last Tuesday had 9 mm rings (outer diameter), and 1mm x 1.5 mm section, and is clearly 15th century. I might provide pics if you ask nicely Wink (and if I can find time to upload them)
PhD in medieval archeology.
HEMAC member
De Taille et d'Estoc director
Michal Plezia
PostPosted: Sat 13 Oct, 2007 12:20 am    Post subject:         Reply with quote
I beg you good sir!Show me those pics! Wink
www.elchon.com
