The barrel accepts a round 1 1/8 dowel. I found a slightly warped piece of ash at Woodworkers Supply in the "please take this" bin, which as it turned out was rather perfect for the project. I reshaped the stock from a round to a tiller shape at the butt end. On the barrel end I chiseled and sanded it to fit into the socket and to fit flush with the stock. Decided to build a snapping serpentine matchlock on this. The match holder is also from TRS and is cut down and reshaped. I cut and rasped a central slot in the stock and pinned the match holder into place. I had a nice 1/4 inch brass rod laying about that I used as a sliding lever/trigger. I am using a coiled spring which is not period but a safety measure so the lock snaps back open and does not fall down towards the vent hole. It can be removed easily if I was to do a re-enactment where folks are fussy. I did not use any power tools on this project - did it all by hand because, I dunno just because.
The serpentine lock allows a firm two hand grip and gets one's face further away from the touch hole. It can be engaged either with the trigger finger of the backhand or by sliding the palm of the forehand. Either way it provides for a two hand grip with the stock either tucked under the armpit or butted to the shoulder.
I was going to shoot it today but the weather turned bad so will have to wait for a week or two to see how it fires. In the meantime I am going to finish the stock and blue the barrel. Although I know you guys are going to tell me to treat the stock with boiled linseed - but I am thinking of applying a darker stain to this one. The light ash for some reason does not seem right to me on this piece.
