Posted: Fri 16 Mar, 2007 11:47 pm Post subject: Distal taper on Feder / Longsword Foil blades.
Hi guys.
Does anyone have any info on the distal taper of these blades other than what is written in the Arma article? Any info on the blade diameters in general?
Posted: Sat 17 Mar, 2007 8:17 am Post subject: Re: Distal taper on Feder / Longsword Foil blades.
I just measured mine. It's just slightly more than 1" wide just ahead of the Schilt and 3/16" thick at that point. It tapers down to approximately 1/2" wide by 1/16th" thick at the point. I hope that helps.Regards,
Hugh
www.schlachtschule.org
