Forum Index > Historical Arms Talk > Distal taper on Feder / Longsword Foil blades. Reply to topic
Alex Mac
PostPosted: Fri 16 Mar, 2007 11:47 pm    Post subject: Distal taper on Feder / Longsword Foil blades.         Reply with quote
Hi guys.
Does anyone have any info on the distal taper of these blades other than what is written in the Arma article? Any info on the blade diameters in general?
Alex.
Hugh Knight
Reading list: 34 books
PostPosted: Sat 17 Mar, 2007 8:17 am    Post subject: Re: Distal taper on Feder / Longsword Foil blades.         Reply with quote
I just measured mine. It's just slightly more than 1" wide just ahead of the Schilt and 3/16" thick at that point. It tapers down to approximately 1/2" wide by 1/16th" thick at the point. I hope that helps.
Hugh
www.schlachtschule.org
Alex Mac
PostPosted: Sat 17 Mar, 2007 4:04 pm    Post subject:         Reply with quote
Hi Hugh,
Is it a gradual taper over the whole length of the blade or does it taper sharply about 1/3 of the way from the tip?
Alex.
Hugh Knight
PostPosted: Sat 17 Mar, 2007 9:25 pm    Post subject:         Reply with quote
Hi,
It appears to taper gradually throughout its entire length.
Hugh
